Stuck caliper after doing brake job grrrrr
Old Jun 1, 2007 | 06:55 AM
Default Stuck caliper after doing brake job grrrrr
So i re-did my brakes all around painted them flat back,new satisfied brakes pro-cermaic pads, fully flushed all the fluide out and stainless lines for the front. Well i of course took apart the calipers on on 4 corners and cleaned and relubed them up. Now I didnt notice before but it seems my front driverside caliper is sticking. It was doing it before but i thought it was fixed once i had cleaned it out and relubed everything.
So the question is, what the heck do i gotta do now? take it off again clean it again and relube the slides etc.... it works fine just doesnt fully release out. And is the only one that does it. Basicly I think i know what i gotta do i am just bitching cause its being a bitch.
Old Jun 1, 2007 | 07:04 AM
Could be partially seized in the inside. Time for a cobra brake upgrade. You might be able to pick up a set of used front calipers for a decent price. I sold my oem brake calipers for 80 at a swap meet.
Old Jun 1, 2007 | 01:10 PM
Like i said in some other posts i don't need them and don't want the extra weight, plus i just did a full fluide and brake upgrade on mine. Just seeing if anyone has any inside tips etc... for what else i might of missed. I will take them apart tomarrow morning and see why its sticking on that side.
Old Jun 1, 2007 | 04:14 PM
You might of put the pads on the wrong side. If you look at the pads they have round bumps on them. If the pads are not on the correct way the bump will cause the pad to be slightly cocked causing it to bind on the rotor. Look at the surface where the rear of the pad meets the rotor.
I couldnt find Mustang specific pads but here is a pic of what Im talking about. Another thing could be air in your lines or Master cylinder if you let it get to low.
Old Jun 1, 2007 | 09:06 PM
No my pads are uniform on all sides so thats not it. Lines bleed alot they are free of air. I am thinking its just stuck on the slides and will need to be cleaned up more. Bur thanks for the ideas.
Old Jun 2, 2007 | 09:53 AM
time to replace the caliper. they don't always last forever.
Old Jun 2, 2007 | 02:38 PM
Well i just cleanned them again it just needed some more lube on the slides and they are good to go.
New Products
New American Muscle Products
Jul 24, 2007 09:30 PM
ZappaFan
Jun 5, 2007 02:13 PM
p3s7_01
Feb 19, 2006 10:02 AM
Lances03SVT
Jan 16, 2006 07:30 PM
Icefreezen
Dec 13, 2005 02:27 PM
