what psi is everyone using?
Old May 25, 2007 | 06:19 AM
Default what psi is everyone using?
ON the 17x8 wheels with stock sized 245's? mine worn very uneven with the pressure ford says to use. I am about to replace them and get an alignment so i dont want to ruin them.
Old May 25, 2007 | 06:23 AM
I run 38 psi on my pirellis.
Old May 25, 2007 | 09:58 PM
blownstang's Avatar
30-32 psi
Old May 26, 2007 | 08:36 AM
on 35psi-max I run 32, on 44 max I run 40, on 52 max I run 40. There's no reason to underinflate performance tires for street use. Drop the pressures in half for drag time.
Old May 26, 2007 | 11:03 AM
07_427r's Avatar
32 PSI in mine.
Old May 27, 2007 | 03:16 PM
32psi and yes its normal for the middle to get bald way before the outside edges. What you get when you have a v8 with RWD haha.
Old May 27, 2007 | 04:52 PM
lol, and for those of us with the sixxers they're a b*tch to rotate! i mean ya got one tire that's almost bald and 3 that are all good.
to hell with the one tire fire!
Old Sep 13, 2007 | 06:18 PM
Ryan's Avatar
30
Old Sep 13, 2007 | 06:40 PM
zigzagg321's Avatar
Ninja
not running stock sizes...but 36-38 rear and 32-34 front.
Old Apr 2, 2008 | 06:44 PM
BigDipper's Avatar
I had a similar problem with my 04 GT. The inside of the front tires were worn out bad and unevenly. When I took it to get aligned,they said it was due to low tire pressure. I was running the 30lbs Ford suggested.Had it re-aligned and put 44lbs in a 50lb tire and no more problems!
Old Apr 2, 2008 | 07:06 PM
Dream's Avatar
bone stock 40-43 psi........i duno y. just a european habit i guess
Old Apr 2, 2008 | 09:31 PM
redfire04's Avatar
Redfire GT
Originally Posted by blownstang
30-32 psi
+1
Old Apr 2, 2008 | 09:47 PM
Dave04Mustang's Avatar
30-32 also
Old Apr 3, 2008 | 10:13 AM
BlackTang01's Avatar
40 HERE
Old Apr 3, 2008 | 12:24 PM
01FR500's Avatar
I'd Hit It
35.5psi for all four corners for me. Usually start at 41.5psi for autoX.
Old Apr 3, 2008 | 12:58 PM
crignaj's Avatar
36 psi all around. I have 275's on all 4 corners on cobra rims.
Old Apr 17, 2008 | 08:25 PM
gimpster's Avatar
Here's a method I've been using for several years now on new tires that works great. The chalk method.
With a cold vehicle and cold tires, air them up way over pressure. 40 psi should be OK. Take a chalk and mark a chalk line sideways across the tread of a front and rear tire. Drive your vehicle several yards (30-60 or so should do it). Now look at the chalk marks.
You should see the inside of the chalk marks worn off of the tread but the outsides should still be showing. In other words, the bowed out overinflated tire was wearing the middle of the tread and not touching the outside of the tread.
Release a couple of pounds of pressure from the tires and repeat the experiment. Continue until the complete chalk marks wear evenly. (You might want to lose another pound to make sure the entire tire is bearing down across the tread once the entire chalk mark disappears at the same time). You have now determined the tire pressure at which you are keeping the entire tread on the road.
Under this pressure you are wasting available fuel economy, generating excess heat, and prematurely wearing the tread. Over this pressure you will get better mileage at the cost of comfort and decreased tread life. Keeping at this pressure will wear the tire evenly and thus extend its life to its greatest extent and offer the best compromise possible between gas mileage, comfort, and safety (you'll have your whole tread on the road). The pressures may be a couple of pounds different between front and back for your particular vehicle application.
Old Apr 17, 2008 | 11:57 PM
Wombozi17's Avatar
that is interesting. well said gimpster. makes sense to me, its worth a try
Old May 24, 2008 | 06:38 PM
nyheyman's Avatar
I just brought new tires. I will give this method a try and let you know how i do.
Thanks
lazyhomie1908
Jan 20, 2009 06:41 AM
jjmustang04
Drag Racing!
Mar 24, 2008 04:19 PM
dannyb785
16
Mar 19, 2007 05:55 PM
backwoodsracing
Feb 23, 2007 02:14 PM
SlicK
Sep 15, 2006 04:57 AM
