air fuel ratio
Old May 15, 2007 | 08:01 PM
Kains03GT's Avatar
Default air fuel ratio
03 gt.Wide band or narrow band for a autometer sport comp guage?Thx
Old May 15, 2007 | 08:40 PM
pretty sure all autometer gauages are narrow band.
Old May 15, 2007 | 08:44 PM
narrow bands are just a half-assed BS idea of what it actually is. Buy a wideband kit.
And yes spike, Autometer makes wideband gauges with digital numeral output.
Originally Posted by www.autometer.com
Notes:
Includes 8 ft. tubing or wiring harness.
LED digital display.
0-4v data output feed for ECU, data acquisition unit, or Laptop tuning
Auto-Dimming gauge brightness feature
Includes high-quality Bosch wideband O2 sensor
Display data in Lambda or numerical A/F ratio
User programmable range
Peak recall/memory
10:1 to 20:1 AFR Range for Gasoline Applications
Adjustable for Alternate Fuel Types (Ethanol, Methanol, Propane, CNG)
6:1 to 18:1 AFR Range for Alternate Fuel Types
User Programmable Warning Function
Old May 16, 2007 | 06:00 AM
when did they start making those?
Old May 16, 2007 | 06:26 AM
theyve been out for quite some time now. they are available for the most popular series.
Old May 16, 2007 | 08:07 AM
does it come with the sensor and controller or just the guage?
In any case, you can use a standard autometer narrowband guage and the Innovate Motorsports LC-1 kit. You won't have the numeric readout but the LED's are easy enough to read if you program the controller properly (easy as hell). Innovate also sells a small digital numeric guage (about the size of a key fob) that you can mount either in conjunction with or instead of the autometer guage. I have this exact setup and I like it quite a lot.
The LM-1 kit is nicer but more expensive. It's probably too much for your application or you'd know already. In any case, wideband is the only useful choice. Narrowband sensors only detect if it's richer or leaner 14.6, not exactly how much richer or leaner so they're not terribly accurate.
Old May 16, 2007 | 02:53 PM
Kains03GT's Avatar
so narrow band is a waste of time and money?I'm saying wide band kits are a huge increase in price.
Old May 16, 2007 | 04:01 PM
narrowband is a disco ball for your dash and not a damn thing else.
wideband is the only useful method. You should also try to decide if you "need" it or just want it. Guages you don't need are just more things to break and wideband sensors start near 75 bucks. You'll have to replace it, infrequently but nonetheless they're expensive.
I needed one so I could do my own tuning. Teal_beast needed on cuz he's running big boost. You probably don't need one but if you do you really do and should definitely not cheap out.
Old May 16, 2007 | 06:46 PM
Autometers wideband kits come with the bosch o2 sensor.
Old May 17, 2007 | 06:12 PM
Kains03GT's Avatar
Good point red
Graderbird2004
Jan 28, 2010 08:28 AM
Bwhipple
Apr 15, 2007 10:53 AM
89stang
Jan 6, 2006 02:03 PM
NoKturnaL
The Reference Section
May 25, 2005 07:19 AM
Apr 26, 2005 10:39 PM
