Kenne Bell Supercharger!
Old May 14, 2007 | 06:47 AM
03_GT's Avatar
Smoke Tires....Not Drugs.
Question Kenne Bell Supercharger!
I was just looking for prices on the Kenne Bell website, and noticed that that intercooled superchargers are more expensive then the non-intercooled ones, Now my questions is, What is the difference if u get a non-interchoold vs intercooled? Whats the difference between them 2?
Old May 14, 2007 | 06:51 AM
swervo's Avatar
Can you hear me now?
You'll be able to run more boost which in turn will make more power than a non-intercooled setup. Might as well do the intercooled version now, than having to tear it all apart to upgrade later on.
Old May 14, 2007 | 06:55 AM
03_GT's Avatar
If i go and do intercooled im gonna want to run a good bit of boost 10-11 psi! am i going to have to build the bottom end in my engine? or will it handle the boost?
Old May 14, 2007 | 06:57 AM
KB's 9 psi kits seem to push close to 400 horsepower and thats about as much power as the stock short block can handle.
Old May 14, 2007 | 07:02 AM
03_GT's Avatar
So if i wanna push more than 400hp then im gonna have to buid a engine?
Old May 14, 2007 | 07:10 AM
swervo's Avatar
Yes, you'll need to build the motor. You can possibly go as high as 420rwhp, but that's pushing it.
Old May 14, 2007 | 07:21 AM
03_GT's Avatar
Ok, Im gonna want more than 420rwhp. Thanks for the help, Im look and prices on some new engines, possible buit ones instead of me building one!
Old May 14, 2007 | 10:36 AM
swervo's Avatar
Check out VT Engines, Modular Mustang Racing, DSS, Steen Racing
Old May 14, 2007 | 12:46 PM
03_GT's Avatar
I just got done talkin to VT Engines, Im gonna go through them!
Old May 14, 2007 | 03:13 PM
swervo's Avatar
good choice man! They are one of the top mod engine builders out there. How much HP are you looking to get? If your planning to push more than 500, you might as well get a KB 2.6 or 2.8.
Old May 14, 2007 | 04:42 PM
Yeap get the bigger KB. One thing to consider is that the KB gives you alot down low so look into a new tranny as well as other supporting parts as they will not last long. You can build your motor then rear end and tranny in prep for the KB or you can run lower boost until you can get all those things done. Im getting my SC done now and know that the tranny is next since Ive done everything else.
Old May 15, 2007 | 07:24 AM
03_GT's Avatar
I want alot more than 500hp, but its gonna take awhile, but its a project for when i move down to Orlando Fl, Since im going to UTI down their!
Old May 15, 2007 | 11:12 AM
Mikeaveli's Avatar
If you want more than 500hp, the long block would have to be upgraded, transmission and clutch, and rear end. You'll also need a good suspension setup and tires so you can at least get some traction.
Old May 15, 2007 | 03:11 PM
Stan's Avatar
Beantown Stang
say if you get the intercooled setup.. and dont plan on upgrading your engine anytime soon what PSI would be safe to run it at?
Old May 15, 2007 | 03:20 PM
Mikeaveli's Avatar
9 psi.
Old May 15, 2007 | 03:27 PM
Stan's Avatar
Beantown Stang
Originally Posted by Mikeaveli
9 psi.
will that be a lot of wear and tear on your transmission etc.. or does it depend on how hard and often you run it hard?
Old May 15, 2007 | 05:22 PM
Mikeaveli's Avatar
Well 9 psi is the standard boost level that Kenne Bell gives you when you order a intercooled kit. As for wear and tear, depends on how you drive and how well you maintain your car. Things will break though, it's unavoidable.
Old Jun 9, 2007 | 06:17 PM
Blown00's Avatar
I just recently installed a KB charger on my 00gt! Currently I am running 6 psi intercooled (cause I live in a desert) and as soon as I make some suspension changes (traction issue) I'll put the 9psi pulley on. Imo it was a great investment. So far Brakes/suspension/tires are my biggest concerns right now and until I blow my engine 9psi is where I'll stay at.
Old Jun 20, 2007 | 09:32 AM
jjgt06's Avatar
dude,dont waste your cash on short tube headers!!! get long tubes,way better,short tubes are just like a little lighter stock manifolds!!
BraggStang
Feb 16, 2006 08:43 AM
budthachud
Aug 7, 2005 04:37 PM
ModMotorRacer
54
May 10, 2005 05:11 PM
White2004
31
Jan 2, 2005 03:09 PM
Ozone89
Sep 30, 2004 07:22 AM
