Gear Confusion
Old May 3, 2007 | 04:09 PM
redrider95's Avatar
Mustang Madness
Default Gear Confusion
I searched some of the other forums but wasnt quite sure if i understood some of the stuff with the gears
If i wanna get 4.10 gears does the speedometer need re-calibrated?
I Have a '95 V6 Auto
Old May 3, 2007 | 05:46 PM
mustangvsix's Avatar
4 point 6
yes it does. But since you have a 94-98 model mustang, i am 99% sure that you can buy a "speedo gear" from like autozone or something. Not sure how much they are, but i think they are like 5 bucks and will fix it for you. The 99-04 guys use the Tuners because our speedos are controlled by the computer.
but someone should double check me on the gear thing.
Old May 3, 2007 | 06:44 PM
like he said you can just replace the gear in the tranny to the fix the speedo at the sensor.
Here is a link just pick the one you need:
http://www.steeda.com/products/speed...tion_gears.php
Old May 3, 2007 | 06:45 PM
yes you need to recal.
i think they have speed cal on AM.com
Old May 3, 2007 | 06:47 PM
Dont need speed cal on 98 and older models it will not work. You can do it for sooo much cheaper and in the 96-98 cars (which can have a tuner adjust the speedo) its still cheaper to just replace the plastic gear in the tranny for all 98 and older cars.
Old May 3, 2007 | 07:43 PM
redrider95's Avatar
Mustang Madness
k thanks, appreciate the help
Old May 3, 2007 | 07:44 PM
well i think obdII flash tuner is the best but they didnt come back then did they
Old May 4, 2007 | 05:17 AM
Flashers didnt come around till 2001ish and they were crap i had one. Regardless get the speedo gear from steeda nd install its easy and will fix your problem cheap.
Old May 4, 2007 | 01:44 PM
95STANG's Avatar
In heven there is no beer
Do you have to drop the tranny to replace the speedo gear?
Old May 5, 2007 | 02:05 PM
no its on the side of the tranny.
tr6nut
Feb 15, 2010 07:57 PM
Squishy125
Jul 6, 2009 04:13 PM
Black Sunshine
Nov 24, 2008 10:39 AM
NoKturnaL
Jun 22, 2006 10:06 PM
Slither
Nov 17, 2005 11:26 AM
