heard anything about this?
Old Apr 29, 2007 | 09:50 PM
another small plenum long runner intake. If they'd shorten the runners a bit and open up the plenum then it'd be more useful on cars that it's worth a tinkers damn on anyway. Stock to mild bolt on cars will get nothing, cammed and more serious engines will see modest gains. A MUCH bigger plenum would help but the runners are 12" long... jeebus. I'd like to see one check in at 10ish.
Old Apr 30, 2007 | 05:19 AM
G PURE 260 STANG T's Avatar
I HEART MUSTANGS
when is someone going to come out with an intake that is worth while i mean if there is one out there let me know. wasnt there all that hype for that powerballer intake that you got red? and it wasnt that great in the end?
Old Apr 30, 2007 | 06:25 AM
The problem is that the stock PI intake is a perfect match for the 4.6. Improving it is very hard to do and it seems that Trick Flow and HPS got part of the pieces. Trick Flow straightened the runners but HPS enlarged the plenum. In the end, you aren't going to get massive gains, except in the area under the curve and for the money, it isn't worth it. My money though is going to be on the Edelbrock intake, if it ever comes out...
Old Apr 30, 2007 | 08:16 AM
The hardball'R that I have is a great intake, particularly for my use case. It has a huge plenum and can, like mine has, be heavily ported for even more flow. It's a solution to a couple specific problems. Fragility and plenum size are the biggest among them. The thing seems to really help cars that have had too much cam stuck in em'... like comp xe278's on an otherwise stock motor (You know... stuff people do after being suckered in by hp claims in advertising), and stroker and blower motors as you might expect see nice gains but not magical gains.
And I don't know what you mean by not that great in the end. I don't know of many tests that didn't come out with exactly what was expected of them.
You nailed it exactly on the head. Too often we forget that people with Ph D's designed the stock intake to be a perfect match for street biased performance use of the 2v 4.6. They did a great job. We're asking for something a little more than that and that takes R&D. Trick flow nailed what looks like a modified version of the bullit with shorter runners. 12" is still a bit long but maybe it can be tweeked. Who knows.
Edelbrock has one...for carb'd and custom efi. Short runner single plane IIRC. Not terribly useful for most but on a blower or turbo car it'd be neato.
Old Apr 30, 2007 | 08:24 AM
2Eighty1's Avatar
If they ever release it, I'll use that along with a Sullivan hat on my 5.4
The Edelbrock has been "coming soon" for almost 2 years now.
Old Apr 30, 2007 | 10:16 AM
I was in line to get one for a very god price got tired of waiting and came across a bullitt intake that i'm gonna get instead at least it's proven HP
Old May 1, 2007 | 08:09 AM
not really.. there's a whole install kit for it. Several irritating details change with the bullit. Nothing major but just a PITA. The Hardball'r and Typhoon both bolt up quick and easy with no changes.
Old May 1, 2007 | 10:06 AM
3V2000GT's Avatar
46MONSTER
here is the intake that the shop that does all my work developed-
www.loganmotorsports.com
Old May 1, 2007 | 06:42 PM
The same gain as w/ FRPP shorties: not worth the money or hassle.
Old May 1, 2007 | 07:45 PM
so, like 5-10 hp? damn I thought a Bullitt intake would give more.
With any of these intakes it's all about forced induction. You wanna see some numbers port your heads, cam it, and get some long tubes and you'll see how much it's worth
Old May 2, 2007 | 08:49 AM
2Eighty1's Avatar
This is true
And although the bullitt intake will give you 5-10 PEAK horsepower.
The power gains down low are in the 20-30 range, it gives you a much better powerband.
Old May 2, 2007 | 10:26 AM
Not with the Bullitt intake. The point of the Bullitt is better top-end power w/o sacraficing low-end. The Bullitt's low-end is the same as a stock PI intake but w/ a better top-end.
Old May 2, 2007 | 10:30 AM
2Eighty1's Avatar
I gained 23 RWHP by 3500 RPM with mine...
Peak gain was 7 RWHP and my peak was a few RPM's higher then the PI
Old May 3, 2007 | 01:44 PM
Is yours supercharged?
Old May 3, 2007 | 02:01 PM
2Eighty1's Avatar
No sir.
Just exhaust, intake, and a JLT
Old May 4, 2007 | 08:02 AM
Strange since most of the dyno charts I've seen show only improvement in the upper rpms while the lower stayed the same. Whatever, you see something new everyday...
Old May 9, 2007 | 06:06 AM
ex-ricer98gt's Avatar
i read somewhere that bbk is comming out with an intake for the 2v, anyone hear about that?
Old May 9, 2007 | 06:56 AM
It's on their site, due out this summer I believe.
Sep 20, 2005 05:19 PM
cobra4123
Aug 22, 2005 05:45 AM
Jul 27, 2005 06:21 PM
MineralGT
Jun 28, 2005 08:45 PM
burnsmustang
Tire and Wheel Talk!
May 31, 2005 11:52 AM
