Blew my rear end! Question on new gears..
Old Apr 24, 2007 | 11:49 PM
  #31
stangracer44t's Avatar
the ring and pinion should be fairly cheap, as for the inner gears the same thing happened to me. you can get the posi-lock differential that comes with the 4 inner gears plusthe s plate inside that for i thing around 300 brand new. Its definately worth upgrading to that.
Old Apr 25, 2007 | 05:35 AM
  #33
simbill's Avatar
Originally Posted by wnracing
Should I even ask you why you have a six banger with Cobra badges and blingin' rims?
LAWLZ @ TEH GAYNIS!
LMAO
Old Apr 25, 2007 | 06:44 AM
  #34
The 8.8 is a direct bolt on if you get the full rear end.
Old Apr 26, 2007 | 04:34 PM
  #35
simbill's Avatar
okay, so me and my father have everything installed and almost connected the driveshaft and closed the cover for the pumpkin.. and we notice a little lash between the ring & pinion. Barely enough to see it move, but you can slightly hear it. Is that much going to cause a problem? What can we do to eliminate this? A slightly bigger shim on either side? Or is a small amount of lash normal?
Old Apr 26, 2007 | 06:07 PM
  #36
the best deal is use the paint the install kit comes with to see how the teeth are wearing and add shims as needed per how the wear pattern looks.
Old Apr 26, 2007 | 06:26 PM
  #37
simbill's Avatar
hmm.. is there a way to move the pinion back or forward? or shim it? we have both the sides where the axles come through all shimmed very tight, had to tap with a hammer lightly to get it in..
Old Apr 26, 2007 | 06:53 PM
  #38
Yes you can add shims to the pinion gear to bring it out farther.
After that use the paint method where you add some paint on 2-3 teeth and spin the axles and you can see where the gears mess and you want them to be in the middle and not to the one sid eor the other and not to far out or in on the teeth.
Old Apr 27, 2007 | 12:22 AM
  #40
99-04 need to be tuned, as for 94-98 i believe there is a gear behind your cluster that you need to change but don't quote me on it.
Old Apr 27, 2007 | 05:14 AM
  #41
simbill's Avatar
Im going to look into pinion shims today and the auto parts store in town.. thanks!
as for a tuner? nah man, that sct stuff is sooo expensive. If I could get a tune for around $200-$250 i wouldnt be so afraid of buying it. I mean the benefits are crazy i could mess with shift pressure, comp codes, tires, gear ratios, etc. Just too damn expensive for me right now.
Old Apr 27, 2007 | 06:28 AM
  #42
YOu do know that your speedo will be off. ANd if you search around you can get used tuners for pretty cheap so you can fix that speedo and gain a few poines too
And for the speedo if your 99-07 you have to get a tune. If your older then that you can change the speedo gear in the tranny or 94-98 can have a tune uploaded to change it also.
Old Apr 28, 2007 | 11:54 AM
  #43
simbill's Avatar
got them all installed and whatnot now, everything works perfect. first thing i did was floor it onto the main road and i almost died... haha. highway isn't that bad, even though 80mph (guessing lol) is going at 3000rpm... defiantly a MAJOR improvement over stock 3.11 or 3.23 (i forget)
Old Apr 28, 2007 | 01:21 PM
  #44
doobie's Avatar
skin and bones
lol you should really go easy on it for a while, let it break in for a few hundred miles before you get on it. i would lay off on it for a while.
Old Apr 28, 2007 | 08:06 PM
  #45
1982 mustang 5.0's Avatar
there is no need for a breakin just get on them i got on mine once mine were installed and nothing happend
Old Apr 29, 2007 | 09:47 AM
  #46
simbill's Avatar
their used anyway, no break in. loving them to death!
Old May 1, 2007 | 05:08 PM
  #47
As for the mechanical or computer controlled spedomoter here is your answer courtesy of AM.
"Mustangs after 1999 use computer controlled gauges and can be calibrated with the tunes for gear and odd tire size changes. Pre-1999 Mustangs use a mechanical speedometer so the car's computer has no control over the speed reading. A rotating cable runs from the Mustang transmission into the back of the speedometer. The tuners can not be used to calibrate for gear changes on these cars. You can however calibrate for gear changes by replacing the speedometer driver gear at the transmission end of the cable. They are available from most transmission shops, or online at http://www.steeda.com or http://www.50resto.com for about $10-20 and are color coded (for the Mustang transmission type and gear ratio) and are easy to replace."
pine9280
Oct 14, 2011 01:49 PM
curtis22
May 4, 2009 04:54 PM
Lapse138
Jul 9, 2008 07:38 AM
3V2000GT
May 3, 2007 11:57 AM
Ron
Mar 18, 2006 03:54 PM
