advice needed for sirius radio
I am tired of leaving my sirius tuner on after forgetting to turn it off when exiting my car. I currently have it powered by using the cigarette lighter adapter it came with. My question is, what would be the best wire to tap into for a keyed on switch? Or is there a better way?
If you remove the plastic plate under your steering wheel, you will find a red wire with a green strip. This is a "keyed-on" power supply. You can then buy a cigarette lighter adapter and wire it to this wire and a ground. Then, just plug in the radio right into it and hide it.
I have always found an ignition on power lead on the fuse box usually without a fuse. My wifes car Cig light turns off when car is powered off but Im on the same boat as our stangs always have current. I may just run the positive from the cig lighter to the fuse box ignition source.
lol...maybe I can wire it into the power supply to my cd receiver which is keyed on? wonder if that would work?
You can do that. You can buy a 2 cig splitter hard wire that then connect your sirrus and have an extra connection for a cell phone charger, that way you wont damage the sirius car charger and have another port open for something else. Where are you going to mount your sirius? I put mine right on the shifter bezel below the radio mounted horizontal.
Good idea, I just did mine the lazy way and vent mounted it. Did you use a special bracket to install yours there. Mine really doesn't give me any problems where it is mounted and has easy access to the screen and functions.
I used the flexible stickon bracket which cannot be seen since the unit is vert. I ll post a pic so you can see. Its out of the way and in a dead space. I have the S50 so it may not look right with the older models.
You can buy a cig adaptor at radio shack and it has a built-in fuse. This is the style with a female end. You hard wire this to the power on supply and then plug the XM radio into that. This way you can always unplug the radio in the future and easily plug anything else into it.
