valve cover removal
Old Apr 17, 2007 | 01:22 PM
chatmanv6's Avatar
ChatmanV8
Default valve cover removal
is it safe to take off the valve cover on a 2002 gt...i am doing this to paint them and hopefully tighten my headers while i'm at it...any problems i might run into ..thanks for any info
Old Apr 17, 2007 | 01:43 PM
Its ok to take off your valve covers. Dont paint the inside of them though.
Old Apr 17, 2007 | 01:59 PM
chatmanv6's Avatar
ChatmanV8
ya i don't plan on paintin the inside...i was just wonderin bout oil spillin anywhere or gasket crap..thanks for the help
Old Apr 17, 2007 | 03:13 PM
be careful and you can reuse the gaskets. they're rubber and can tear but if you're nice about it they're not a problem. enjoy.
Old Apr 17, 2007 | 05:01 PM
chatmanv6's Avatar
ChatmanV8
is there anything i can do performance wise while i have them off thats not to hard of a job??
Old Apr 17, 2007 | 05:55 PM
the only thing you can do by only taking the covers off is a cam swap, and its not easy. For the nay sayers you can do a cam swap with the front cover still on if you use the AFM tool. Only cars with screwed on cam gears can do that though. I forget the years you can do that.
Old Apr 17, 2007 | 06:31 PM
Windsor engines are the only only ones w/ the press on gears so only 96-98 and 01+ can do that.
Old Apr 17, 2007 | 07:52 PM
phil_the_thrill's Avatar
so if you can do cams without taking the front cover off you should be able to do heads too without taking the front cover off correct. just a couple more bolts right???
Old Apr 17, 2007 | 08:30 PM
no if you want to swap heads the front cover has to come off. I was just making a point that there is no easy mod you can do under the valve cover.
Old Apr 17, 2007 | 08:43 PM
there is about dik you can do with the covers off short of a cam swap. You can pull all the lash adjusters and slap some .010 shims under em... probably get PTV contact but you asked for anything so there you go.
FYI... don't. You'll destroy your engine.
Old Apr 18, 2007 | 03:40 PM
chatmanv6's Avatar
ChatmanV8
thanks everyone for the help..ocvers gettin painted this weekend along wit some other stuff
ANDYS87
Apr 18, 2008 11:47 AM
Kains03GT
Sep 5, 2007 06:12 AM
Jul 19, 2007 10:39 AM
ANDYS87
Apr 17, 2007 06:41 PM
stocksilver02
Oct 4, 2006 09:53 AM
