getting 315's soon
Old Mar 11, 2007 | 01:40 PM
Stan's Avatar
Beantown Stang
Default getting 315's soon
im getting rear 17x10.5 03 cobras with 315/35/17 goodyear F1 GS-D3 tires, car is 02 gt will i need to get anything else for this to work? car is lowered with H&R supersports... will i have any problem with rubbing or anything with this setup? ordering soon for the summer..
Old Mar 11, 2007 | 03:47 PM
You should be fine.
Old Mar 11, 2007 | 04:11 PM
if it rubs, itll be on the quad shock or your catback
Old Mar 11, 2007 | 04:34 PM
Stan's Avatar
Beantown Stang
i know how to fix the catback issue if it rubs but what can i do if its the shock issue?
Old Mar 11, 2007 | 04:39 PM
get control arms and get rid of the quad shocks. its there to help prevent wheel hop and if you have aftermarket control arms, itll fix a lot of that problem too.
Old Mar 11, 2007 | 04:43 PM
Stan's Avatar
Beantown Stang
lance when you had your old gt what tire size your run out back?
Old Mar 11, 2007 | 05:06 PM
They were only 285/35/18's.
Old Mar 11, 2007 | 06:00 PM
Stan's Avatar
Beantown Stang
and no rubbing issues? you think 315's will be fine?
Old Mar 11, 2007 | 06:06 PM
Alot of people run 315's with no problem's.Hell if I can get them on my Cobra you should be able to on your GT.
Old Mar 11, 2007 | 07:50 PM
I run 315's with no rubbing. I have the Bullet suspension which is a bit higher then yours, but you should be fine.
Old Mar 12, 2007 | 11:15 AM
MOTT's Avatar
OUTCAST
You're going to get a lot of grip with that wide a tire, is the rest of your drive train ready for that? Also, you might want to weld in your boxes, and add subframe bracing to start with.
Old Apr 23, 2007 | 08:34 PM
blackstang01's Avatar
If the tires rub on tha quad then you can turn it 180 degrees and that should give your tires a bit more room, and yeah 315's and stock clutch's dont mix lol
Old Apr 23, 2007 | 10:36 PM
csledd's Avatar
DSG!!!
shouldn't have any problems as far as rubbing because its lowered.. those are the same height as your stock tires I do believe.
Old Apr 25, 2007 | 10:06 AM
just dont try and do a burnout at tha drag strip. but im sure it was time for that clutch to go anyways
PureStang
50
Sep 20, 2008 06:15 AM
GottiDC
172
Sep 13, 2008 08:50 PM
98greengoblin
Feb 13, 2008 04:52 PM
burnsmustang
Sep 3, 2005 09:59 PM
dannyb785
29
Jul 15, 2005 03:04 AM
