Nitrous Kit Question
Old Feb 28, 2007 | 09:12 AM
ShapeShifter's Avatar
Default Nitrous Kit Question
k, i will be buying a kit within the next 2 days, im purchasing it off americanmuscle.com...the one i was looking to get was the NX Kit, but when i was looking thru AM.com i noticed there was 2 difft kits, the reg.EFI kit and then the EFI Plate Kit...which would you think would be better?
EFI Plate Kit
http://www.americanmuscle.com/nx-efi...2vgt-9604.html
EFI Kit
http://www.americanmuscle.com/niexfoefikin.html
Old Feb 28, 2007 | 09:19 AM
the plate kit is a built in intake restriction and would probably cost you a few hp without the juice going. The fogger would be my choice.
And a fogger is hella quick to remove when needed.
Old Feb 28, 2007 | 09:23 AM
cuban3jumper's Avatar
Your local V6 Guy
Hella LOL.
Well actually a plate kit would be simpler to remove sine with a fogger you have to drill in a hole for the fogger. If you're going with a NX kit I would go with a fogger though. It's simpler to hide, if you'd like to hide it, and they don't make a plate kit for my sixer so plate kits suck! LOL. Nah either way you go they're good kits, and don't worry about the restriction of a plate it's not that big of a deal.
Old Feb 28, 2007 | 11:00 AM
hmm what to do, what to do..?
Old Feb 28, 2007 | 11:01 AM
Your local V6 Guy
Just pick one LOL. It's not that big a deal if you want to switch over later it's not hard.
Old Feb 28, 2007 | 11:07 AM
why don't you buy my NOSzle kit... It's complete and I'll let you have it for a helluva good price.
Old Feb 28, 2007 | 11:15 AM
lol yeah im gonna go with the reg. EFI Kit, i appreciate the offer r3dn3ck but i really want an NX Kit since their systems are rated at the rear wheels unlike other like NOS that are rated at the flywheel,thanks guys!
Old Feb 28, 2007 | 11:25 AM
Your local V6 Guy
Cool now go ahead order up a svt pump and a genx2 kit and spray a 125 shot. Have fun in the low 13's to high 12's
Old Feb 28, 2007 | 11:34 AM
No worries... I'm down wit that.
<My $.02> ratings mean dik. it's the tuning that determines the actual gain. From what I've seen... you use a NOS or a Zex or Venom 100hp shot and you get every bit of 100hp at the tires and usually like 125tq. </My $.02>
that said, whatever makes you comfortable is what you should own. No sense in having fun if you're worried all the time.
Old Feb 28, 2007 | 12:19 PM
The plate kits have a serious lean spike. Thats why you should go with the nozzle kit.
Old Feb 28, 2007 | 03:48 PM
plus 2 unless you get it dyno tuned and a tuner can help with that spike alot.
Old Feb 28, 2007 | 06:01 PM
Takes a good amount of tuning. The nozzle kit is just easier to work with. I HIGHY suggest a dyno tune either way.
Old Mar 3, 2007 | 10:34 AM
thanks for all the replies gents, but bought Badfish' NX Kit for a great deal!!
Old Mar 3, 2007 | 04:42 PM
as long as you got something i am happy.
Old Mar 3, 2007 | 11:14 PM
Your local V6 Guy
And isn't that the real reason any of us mod our cars. To make Spike happy
Old Mar 6, 2007 | 02:02 AM
another question, what should i set the Window Swithc to? im thinking start spraying at 3300-3500RPM up to....? that is my question, my custom has the Rev Limiter at 6500RPM...lemme know!
Old Mar 6, 2007 | 06:25 AM
3,000rpms off and i use 5,700rpms off. But i power shift threw the gears so i need it off a bit before the limiter too make sure the nitrous is out of the manifold. I dont know your mods so just i would say 5,800rpms is pretty safe rpm to shift at with out getting out of your rpm rang.
Old Mar 6, 2007 | 11:08 AM
hehe,shift...my car is an auto..ive got pretty much every little bolt-on except longtubes, and i have 4.10 gears...so...
Old Mar 6, 2007 | 12:30 PM
04GTAMPA's Avatar
Default How bad is it to install?
I can get a venom system, new with everything needed for $300.00. The local shop I go to charges $1000.00 for the whole thing, installed and the ZEX system 100 shot + the dyno tune. What's worth?
Old Mar 6, 2007 | 04:16 PM
You need to start your own thread and im not totaly sure what your even asking.
If you have an auto i dont know you got a window switch with the auto its only a matter of flip it on over 3,000rpms and then when your done you lift off the thorttle and the kit turns off. Buut since you have it again 3k on and have it set for just higher then your shift points so it sprays threw the shifts for maximum power. By now i hope you have upgraded your tranny with a j-mod and cooler or the like.
Old Mar 7, 2007 | 11:29 AM
dont have the J-mod but a tranny cooler is on the way
Old Mar 7, 2007 | 01:44 PM
The next mod you do should be j-mod (or the like) and a cooler for the tranny. You do not want it to slip and eat up the clutch packs when your on the bottle. Its cheap and easy to do so make that your next event of mods. YOu also drop around a tenth in the 1/4 with a valve body mods.
Old Mar 8, 2007 | 12:35 AM
cool, well i'll look into the J-Mod gonna install tranny cooler and NX and see how it goes from there, thanks for the help Spike!!
Old Mar 8, 2007 | 06:37 AM
  #24
No problem man. Let me know if you need some help with the install. I have installed a "few" nitrous kits in my days
40thblckgt
27
Sep 9, 2007 08:23 PM
New Products
New American Muscle Products
Aug 2, 2006 03:05 PM
New Products
Jul 16, 2006 07:20 AM
NoKturnaL
May 15, 2005 09:52 AM
