King Cobra vs. Spec Stage 1
Old Feb 21, 2007 | 09:09 PM
CCM's Avatar
CCM
Default King Cobra vs. Spec Stage 1
Which clutch should I get? And which flywheel. Does it even matter?
Old Feb 21, 2007 | 09:27 PM
3V2000GT's Avatar
46MONSTER
I know, My spec stage 2 that only has 1000 miles on it, Ill sell it for 220 shipped. and get a billet steel flywheel
Im willing to make a deal I need to get rid of this thing
Old Feb 22, 2007 | 02:44 AM
wade95's Avatar
Spec=Crap
Just go get a CF DFX or stick w/the King Cobra.
Old Feb 22, 2007 | 05:42 AM
since you have a T45 i take it; i would rock the king cobra cause its cheaper and works well and just get the stock flywheel turned. You want to keep the steel flywheel to have that mass for daily driving. It makes it easier to not stall having a heavy flywheel.
Old Feb 22, 2007 | 07:46 AM
ClemsonStang's Avatar
deffinatly get the king cobra, its what i put in my moms fox. the flywheel is up to you, would you rather pay $40 to get the stoker turned, pay 200 for a steel, or 300+ for an AL?
Old Feb 22, 2007 | 06:52 PM
B-rett's Avatar
BMC Member# 03209
i got a spec 1 with stock flywheel no problems with it
Old Feb 22, 2007 | 06:55 PM
I dont agree with Spec= crap. Tim loves them and is using one in one of his 800-900rwhp cars.
As far as spec 1 or king cobra, I dont think either are all that much better then stock. Id go with a Spec stage 2.
Old Feb 22, 2007 | 07:25 PM
CCM's Avatar
CCM
OK, thanks for your input guys. Another question, when it comes to aftermarket quadrants and firewall adjusters, is there a particular brand you'd recommend? I'm looking at either steeda or maximum motorsports.
Old Feb 22, 2007 | 07:28 PM
Maximum Motorsports... and that rule applys to anything they make. If its available and theres a choice of MM, get MM. They are the industry standard and they are the ones steeda and other manufs try to copy.
Old Feb 22, 2007 | 07:33 PM
Good point.
BTW, have you seen the Granatelli lca's? http://www.granatellimotorsports.com...7998Wsmall.jpg
MM lca's- http://www.maximummotorsports.com/st...p/MMRLCA-2.jpg
Old Feb 22, 2007 | 07:38 PM
CCM's Avatar
CCM
Thanks so much guys, one last question: How do I know if I have a 6 or 8 bolt crankshaft?
EDIT: And does anyone know a coupon code for maximummotorsports.com?
Old Feb 22, 2007 | 07:44 PM
Romeo engines have 6 bolt, and windsor has 8 bolt.
check your vin for a W or X code somewhere in the last 8. X is Windsor block, W is Romeo block.
Old Feb 23, 2007 | 03:56 PM
I have X and it's a Romeo so it isn't the best method. The best is just look at your valve covers. If you have 11 bolts holding it to the head, its Romeo, 13, it's Windsor. Also, if you see a giant W on the block, it's a Windsor.
Old Feb 23, 2007 | 09:50 PM
NetChemica's Avatar
Just to make sure others are aware of this, granatelli's copies of MM's products aren't MM quality. They may look identical, but the craftsmanship is much worse on Granatelli.
New Products
New American Muscle Products
Jul 24, 2007 08:05 PM
Triple 777
Feb 28, 2007 03:07 PM
eventer289
Jan 8, 2007 12:10 PM
03AZRoush
Sep 20, 2006 08:46 PM
Badfish
Feb 25, 2006 10:56 PM
