T45 vs. T3650
Old Feb 20, 2007 | 08:58 PM
CCM's Avatar
CCM
Default T45 vs. T3650
Up until recently, I thought it was T45<T3650. But now I'm hearing that the T45 transmission is much more durable and will last longer as long as you don't power shift it. Two people I know with T3650s have told me they'd rather have a T45, so now I'm starting to wonder which one I should get, or if I should just continue to save and get a T56.
Old Feb 20, 2007 | 09:19 PM
powershifting any tranny is bad for it. youve heard a lot of problems with the 3650s froma flaw from ford. the early 3650s were fine. mine hasnt had a problem yet.
If you are going to get a 5-speed, stick w/ a TKO. Otherwise go for the T56. Also, the TR3650 is stronger than the T45. It's only problem is the TSB to address the 1-2 shift problem.
Old Feb 20, 2007 | 09:42 PM
4.6 Love's Avatar
Exclamation
I haven't had a single problem with my 3650. The only problem i've had is my clutch taking a dump.......otherwise it's pretty stout...
Old Feb 20, 2007 | 10:14 PM
3V2000GT's Avatar
46MONSTER
I had the 3650 for about a month, hated it POS! 5th gear would barely go in and it was hard to get into reverse, i might have gotten a crappy one but my friends 03 does the same thing
go with the TKO 600 and Mcleod twin disc clutch like i did!!
Old Feb 21, 2007 | 11:04 AM
3650 is a fine tranny... not the strongest but a good unit. If you plan to whip it like an orphan then buy a tko. If you're going to be human to it then a 3650 is a great option. I've burned up 3 of them but the failures could always be traced back to clutch issues which seem to have been worked out.
3650 is quite a bit stronger than the t45. You can make a t45 into a pretty stout box too with a little build up action. The dividing line should probably be your budget and how intent you are on trying to break it.
T56's... meh. I think those are really only useful for cars that see road courses with lots of straightaways.
Old Feb 21, 2007 | 03:14 PM
3650 is much better then the tranny that replaced it. thats why the GT's no longer have the T45 anymore.
Bottled GT
Jan 25, 2008 02:27 PM
Blown00
Aug 9, 2007 08:48 PM
brzzle83
Jul 31, 2007 01:50 PM
I<3MySnAke
Jan 24, 2007 12:14 PM
Blk02stang
Mar 7, 2006 04:26 PM
