Sloppy steering on 93 GT
Old Feb 12, 2007 | 03:39 AM
Mirage775's Avatar
Default Sloppy steering on 93 GT
I've only had it a week, but a friend of mine has a 92 LX 5.0 and his steering is a lot tighter/better than mine. I can be crusin down the road at any speed, then the car suddenly wants to pull off the road, one way, then the other, I've heard it called "dancing" before. Is there a front end rebuild kit out there for my GT, like tie rods, ball joints, etc? Thanks, Jason
Old Feb 12, 2007 | 07:14 AM
kit... no.
Replace the following:
A-Arms w/ ball joints
tie rod ends
steering rack bushings
sway bar endlinks and bushings
I spec'd more parts than you probably have "bad". The issue is that you may have damaged any of those parts, particularly the bushings so it's best to replace them.
Old Feb 12, 2007 | 03:20 PM
Mirage775's Avatar
So, when you say a-arms, do you mean replace the bushings in them or buy brand new a-arms??? At 70 mph, the steering wheel shakes a little, then not at all. I'm hoping it's just bad tires or unbalanced tires? This is just a toy and won't be my daily driver, so I will look into these parts in a couple of months. Thanks
Old Feb 12, 2007 | 03:32 PM
you can bend an a-arm... I've done it or I wouldn't mention it. If it's shaking just a little then going away I'll bet ya a dollar it's tie rod ends. I have a heavy duty set with zerk fittings laying around I think... lmk if interested.
Old Feb 14, 2007 | 09:02 PM
Mirage775's Avatar
What are you looking to get for the tie rod ends? Also, where's a good place to buy a-arms at? I was looking at 5.0 Mustang and Super Fords newest magazine and noticed a few ads that had tubular a-arms for $200/pr, if I recall that being correct? Still haven't found steering rack bushings. Like I said in this thread at the beginning, I would love to rebuild the whole front end sometime.
Old Feb 15, 2007 | 06:42 AM
FRPP has control arms w/ a newer designed ball joint. Also, as for rack bushings, check out Prothane or Energy Suspension (just make sure you don't get the ones w/ the offset bolt hole).
Old Feb 15, 2007 | 07:06 AM
yeah... the offset bushings are for tubular K-member guys. they're not usually appropriate to a stockish car.
The ends... gimme 20 bones and 7 for shipping. For control arms... If you have coil overs, then Maximum motorsports a-arms are the best. If not, get the frpp stamped ones (talk to ken at www.speedconcepts.net and tell him r3dn3ck from wildhorses sent you.. he'll hook you up). Check www.steeda.com or www.maximummotorsports.com for steering rack bushings.
If you end up deciding to drop 3K on parts, lemme know and I'll get you a parts list that'll have you carving corners with the best of em.
Old Feb 15, 2007 | 11:19 AM
00blkstanggt's Avatar
Hot, Nasty, Bad ass speed
Hey R3dn3ck, if Mirage doesn't buy those tie rods I could probably use them. I had one replaced a little while back, but I still get a slight vibration when I drive around 50mph and then it goes away. It's not always present.
Old Feb 15, 2007 | 01:41 PM
Mirage775's Avatar
I sent ya a PM, r3dn3ck
Old Feb 16, 2007 | 06:52 PM
Mirage775's Avatar
Should I get alloy or urethane bushings for the steering rack?
Old Feb 16, 2007 | 10:08 PM
Stick w/ poly since the stock k-member isn't the squarest thing.
Old Feb 17, 2007 | 08:46 AM
mega dittos. unless you go to a tubular k-member stick with rubber or poly. aluminum and delrin are best left to more heavily modded setups.
Old Feb 17, 2007 | 04:54 PM
Mirage775's Avatar
Another question about the control, cause I'm making a list of everything I need. If I keep the factory setup, can I still use the MM Control Arms or should I buy the Ford Control Arms? Also, do the Ford ones include urethane bushings? It just says new inner bushings, doesn't say if they're rubber or urethane?
EDIT: Nevermind, I just read that the MM arms only work with coilovers, guess I'll be getting the Ford ones then.
Old Feb 18, 2007 | 11:10 AM
ford arms come with improved durometer (stiffer) rubber bushings. I'd still replace those with poly-urethane if you can swing it. It's a little tiny bit harsher over bumps while steering but the feel is worth it when it matters.
I hate fat girlz
Nov 11, 2005 12:19 AM
StangGT804
Aug 30, 2005 06:15 AM
my2001GT
Feb 14, 2005 08:41 AM
EH819
Jan 9, 2005 08:51 PM
Black01
Nov 25, 2004 07:48 PM
