Audio power cables, Solid Copper Core?
Old Feb 9, 2007 | 06:08 PM
id run anything thats oxygen free copper. doesnt sound like you need much so id run like 8 awg. you want it to be as little resistance as possible. a lot of guys run welding cable for power wire and ground too.
Old Feb 15, 2007 | 11:17 AM
yea I hate 0/1 gauge and other thick wires. I run 8gauge with no problems.
Old Feb 15, 2007 | 12:06 PM
If its too thick and you have the cable you can strip the insulation cut some of the braided wiring if its too thick then use shrink wrap tubing to cover the bare wiring for a clean and safe install.
Old Feb 15, 2007 | 01:06 PM
04DarkShadowGT's Avatar
Generally the larger cable are using is for multi amp applications. You run the 2 gauge or whatever you have into a distribution block then run 8 gauge to each amp.
But in most cases brand doesnt matter, its all made in the same plants on the lines with the same copper and compounds.
Old May 20, 2008 | 09:37 AM
ANDYS87's Avatar
Don't confuse household voltage(120/240V AC) with car voltage (12.5-14V DC). Its like comparing apples to oranges. With your car running, say you have 14V DC. Voltage can be related to the "pressure" pushing the current flow(like pressure pushing water out of a hose). 14 Volts of pressure isn't that much...car audio requires lots of current...add to that the fact that with DC voltage, the electrons have to flow from the battery...thru the load(stereo components, lights, etc)...then back to battery. There is a lot of resistance in the wiring. So, those are the reasons why you need humongo cables for high current draw accessories in your car(also why you need huge fuses). Now, in your house............120V AC....you have a lot more "pressure" to push the current(electrons)...also AC voltage is back and forth(sine wave)...Therefore, smaller wires and circuit breakers can be used.
Old May 20, 2008 | 09:50 AM
ANDYS87's Avatar
The foundation for a good system install is to run a large conductor from your battery back to the trunk to avoid voltage drops, and to carry the current your amps need. In the trunk, step the big wire down using a distribution block to smaller wires going to the amps. It is also recommended to have atleast 1 Farad of capacitance for every 1000W of amplifier power. Capacitors quickly store and release energy that your amps require when a bass note hits. This helps reduce the dimming headlights problem.
Don't skimp on the ground wire either! Add an extra ground from battery under the hood to the body of the car. Also use a heavy gauge wire to ground in the trunk. Match the trunk ground wire size with the large wire coming from the battery to the trunk. Like I said before, in DC circuits, the electrons have to flow thru the entire circuit......so a large power wire and whimpy ground wire isnt good. The small ground wire doesn't allow all the electrons back to the source(conventional current flow), negating the benefits of the heavy power wire.
Old May 20, 2008 | 10:04 AM
Wombozi17's Avatar
have you resolved ur problem jack? its been over a year.... haha
Old May 20, 2008 | 11:14 AM
Crimsonred02's Avatar
This bump is FAIL
Old May 20, 2008 | 11:46 AM
JackThe Ripper's Avatar
Ketchum & Killem
Dear god! This thread has been ressurected form the dead!
IT HAS BECOME...
Sorry andy, just kiddin, thanks for the good info!
Old May 20, 2008 | 12:39 PM
ANDYS87's Avatar
Sorry guys....didn't realize that this thread was over a year old.
Old May 20, 2008 | 01:38 PM
Actually if you are using the hose analogy, the amperage would be the pressure and voltage would be the diameter of the hose, not the pressure.
The reason for the huge cables is that a low voltage (DC) signal requires a lot of amperage to do the same amount of work.
Ohms law: P=IV Power = Current x voltage
say you want 500 watts for your car stereo (DC.) You need 35.7 amps on that 14 volts to get the power you need. 14volts x 35.7Amps = 500 watts
now say you need the same 500 watts in your house (AC.) You only need 4.16 amps with the 120 volts. 120volts x 4.16Amps = 500 watts
Also capacitors for car audio are a waste of money. If you put a capacitor on an already taxed DC electrical system, you are not helping any. In DC analysis capacitors are treated as shorts anyway.
Old May 20, 2008 | 03:07 PM
ANDYS87's Avatar
Not to start an arguement, but the voltage is the "pressure" that pushes the flow of electrons(current-measured in amperes) through the conductor. I'm an electrical engineer and work at an electrical utility company( I have a little background in that). Maybe you learned the water analogy differently???? Also, Ohm's Law is V=IxR. P=VI is a very good equation for this comparison though(I was trying to keep it simple and avoid even basic equations)...And capacitors are helpful in car audio systems. They aren't a majic fix for a weak battery, thin wires, weak alternator, etc....but in a properly designed system they really do help. I have had them in most of my systems. If they had no use, why would all competition vehicles use them? Aside from competition vehicles, my friend had a decent system in his car, with just marginal wiring. The headlights would dim like crazy...he installed a cap, and it eliminated about 75% of the dimming. Wasn't a bad fix for less than $100. Just ask Richard Clark about capacitors use in car audio. He introduced them into car audio back in the day and trademarked the term "stiffening capacitor". They also filter noise if present in the power cables.
Old May 20, 2008 | 03:19 PM
ohms law:
I= V/R
I= P/V
I= Square root of (P/R)
R= V/I
R= P/I^2
R= V^2/P
P= V^2/R
P= I^2 times R
P= IV
V= IR
V= Square root of (PR)
V= P/I
More schooling for you when I have more time
Old May 20, 2008 | 03:57 PM
Ketchum & Killem
Old May 20, 2008 | 04:20 PM
I know total nerd fight going on right?
http://en.wikipedia.org/wiki/Car_audio
Originally Posted by Wikipedia
These large capacitors may not cure headlight and/or interior light dimming as this is a sign of too little amperage from the alternator. A capacitor is only good so far as the audio system isn't trying to pull too much from the electrical system. A capacitor doesn't provide more power, it's designed to 'stiffen' the voltage to the amp, nothing else. If the current isn't there, a cap won't help.
Old May 20, 2008 | 06:40 PM
ANDYS87's Avatar
Don't bother "schooling" me....unless you have a master's degree in electrical engineering..... you don't even remember that voltage is "pressure"(you said amperage is pressure- WRONG grasshopper). You are just throwing out highschool level basic DC formulas. Look up OHM's law: V=IxR. A few pages in your text book later you will find the POWER formula, that you are so proud of. When you have the "time", maybe school yourself or keep quiet. Lets get back to cars now...................This is a nerd fight! I'm an electrical engineer now...but used to be a auto technician in my "cooler" days!
Old May 20, 2008 | 08:22 PM
Wombozi17's Avatar
i like turtles
Old May 21, 2008 | 04:49 AM
ANDYS87's Avatar
Haha....yes, turtles are nice quiet littles creatures!
Old May 21, 2008 | 04:53 AM
ANDYS87's Avatar
Just to beat a dead horse.....here's Richard Clark's reply:
Hi Richard,
I've written you before. Was a huge fan of you and your "sound system" GN back in the good old days. Reasons why I went into electrical engineering.... Anyways, this guy on a Mustang forum(american muscle.com) is throwing out basic highschool DC formulas and trying to "school" me. There's always an ******* out there! Anyways, he says that capacitors for car audio purposes are useless. You are the stiffening capacitor "GOD" so I thought I'd get your take on it. I will paste what he said below:
__________________................................ ...........
Ok, he thinks amperage is electrical "pressure"...back to highschool for him! What is your take on his capacitor arguement?
Thanks for your time.
Andy
he's obviously not too bright or he failed to pay attention in his circuits class-------i really hate arguing with idiots on the internet-------it really gets old after about two paragraphs.............RRC
__________________
Richard Clark at AMI
Old May 21, 2008 | 04:55 AM
ANDYS87's Avatar
DONE.........
Lets talk fun stuff now
Old May 21, 2008 | 02:41 PM
When you're done making lame attempts at insulting me, you can go ahead and post up some evidence to back up your capacitor nonsense. Here, let me RE-POST mine:
Like I said before, if your electrical system is already pushing it's limits, a capacitor WILL NOT help
Now let me explain the hose analogy again. The voltage would be the diameter of the house, and the Amperage would be how quickly the water flows out of that hose. The actual amount of total water can represent wattage.
Say you need 1 gallon per minute of water, and you have two hoses, one that is 1/2 inch in diameter (DC power) and one that is 10 inches in diameter. (AC power)
The 1/2 inch hose is going to need to flow very fast to get the gallon out in a minute. It needs a lot of "current"
That ten inch diameter hose on the other hand isn't going to need to flow very fast to meet those requirements, So it doesn't need as much "current," to put out the same gallon of water
Old May 21, 2008 | 02:52 PM
  #24
Since double posting seems to be the thing, this info ^^ is correct, although it is being taught using different terminology now.
The foundation for a good system install is to run a large conductor from your battery back to the trunk to avoid voltage drops, and to carry the current your amps need. In the trunk, step the big wire down using a distribution block to smaller wires going to the amps.This is also good info
It is also recommended to have atleast 1 Farad of capacitance for every 1000W of amplifier power.Unnecessary
Capacitors quickly store and release energy that your amps require when a bass note hits.Technically true
This helps reduce the dimming headlights problem. Untrue
Don't skimp on the ground wire either! Add an extra ground from battery under the hood to the body of the car. Also use a heavy gauge wire to ground in the trunk. Match the trunk ground wire size with the large wire coming from the battery to the trunk. Like I said before, in DC circuits, the electrons have to flow thru the entire circuit......so a large power wire and whimpy ground wire isnt good. The small ground wire doesn't allow all the electrons back to the source(conventional current flow), negating the benefits of the heavy power wire.Also true
mustangV6_04
May 15, 2009 05:45 PM
PureStang
Dec 22, 2008 11:38 AM
04MustangGT
Sep 15, 2006 09:31 AM
Mr.Whipple
Apr 3, 2006 04:24 PM
Badfish
Dec 25, 2005 11:42 AM
