MAF Adapter plate???
Old Feb 8, 2007 | 10:04 AM
blackstang01's Avatar
Default MAF Adapter plate???
i currently have a C&L intake system comlplete with the 80mm MAF. I have read in the sticky on this board that it could be harmfull to a basicly stock motor(make it run lean). so im going to put the stock one back in to the intake system but the Aftermarket filter is bigger then that Stock MAF 4 inchs i think. Does anybody know where i can get a Adapter plate for this promblem???
Old Feb 8, 2007 | 10:37 AM
It can cause your car to run lean. The best thing to do is go get a dyno run with A/F reading and see if it's actually causing it to be too lean. Other than that you're gunna have to get custom on it.
Old Feb 8, 2007 | 12:11 PM
Just get a new filter.
Old Feb 9, 2007 | 09:56 AM
yeah but its a bad *** filter lol.....im sure its cheaper to get an adaper than a whole new filter, ill just make one or something
Old Feb 9, 2007 | 10:10 AM
just run the stock maf on the big adapter/filter. it wont hurt anything.
Old Feb 9, 2007 | 04:32 PM
you mean put the stock MAF behind tha C&L MAF? theres no way that will fit.the filter barely fits under the hood as it is. there has to be somebody who knows where to buy an adapter???
Old Feb 11, 2007 | 08:40 AM
no he means not to use the C&L maf which I totally agree with. Every time I've seen a C&L MAF on a car it's AF has gotten all hosed because of it. Just leave the stock MAF on. you should be able too figure out a way to get the stock maf to use your shiny new filter. Probably going to have to cut off the stock flange where it attaches to the stock AF housing, then clamp a filter in place. I'd sell the C&L kit and get something lighter. They DO NOT make power.. you'll see like 1hp tops.
Old Feb 13, 2007 | 03:42 PM
okay so back to the reason i posted my question.....does anybody know were to get and MAF Adapter???
Old Feb 13, 2007 | 03:46 PM
you'll want to post pics of what you have, where you're problem is and what you expect to do about it. We've given you what we have for advice but there's no such thing outside something that you cobble together. Start cobbling.
Old Feb 14, 2007 | 06:28 AM
theres a pic or what im talking about in the attached files. screws on to the MAF so that you can run and aftermarket filter(K&N)
Old Feb 14, 2007 | 06:37 AM
dood they sell those at autozone or pretty much any performance shop.
Jacob
Apr 26, 2010 02:28 PM
sk84life
Apr 18, 2006 07:37 PM
jeredan2003
The Reference Section
Feb 23, 2006 07:34 PM
Saleen S330
25
Feb 1, 2006 09:35 AM
73coupe99v6
May 8, 2005 01:10 PM
