Dyno Results Post your actual dyono results here for all to view.
98 GT dyno numbers
Old Feb 2, 2007 | 11:09 PM
98-GT's Avatar
Default 98 GT dyno numbers
I have a full pi swap, 75mm tb/plenum, underdrive pullies, catted h pipe and flowmaster catback. I ended up with 230 rwhp and 290 rwtq. Im happy with the torque especially since i got all of it by 3500 rpms but am dissapointed by the hp. The car seems to give out at 4500.
Old Feb 3, 2007 | 08:57 AM
auto or manual? regardless those numbers are low. But it doesnt matter. What matters is what it runs at the drag strip.
If it does feel like its crapping out could be a few things:
1-shitty tune
2- cam timing is off
Old Feb 3, 2007 | 07:35 PM
98-GT's Avatar
its manual. the car feels fine driving its just on the dyno graph you can see that its really not making much power after 4500.
Old Feb 4, 2007 | 07:25 AM
White04GT's Avatar
KenneBell Blown
Well from what I've heard on the 96-98 GT's if you do a full pi swap you usually see nice gains and better numbers then the 99-04's..numbers seem low specially from the mods you have listed.
Old Feb 5, 2007 | 09:38 PM
98-GT's Avatar
do u think i could be running out of fuel at high rpms? I no i dont need bigger injectors but maybe a stronger pump? Im not expecting it to give me much power but it sounds like it might help.
Old Feb 6, 2007 | 07:04 AM
did you get your a/f ratio logged? if so that would really tell you if fuel is a problem or not.
Old Feb 8, 2007 | 09:22 PM
98-GT's Avatar
yea i did get my a/f, and it seems fine i guess fuel isnt a problem.
Old Feb 9, 2007 | 06:51 AM
If its not that only things i could think of are cam timing is off or shitty tune. Having the cam timing off ca cost you up to 20hp or more if its really bad. i mean there are alot of small things can make it happen.
Old Feb 9, 2007 | 04:48 PM
98-GT's Avatar
if the cam timing was off would i notice it while driving, because the car seems to run fine to me but i might just be missing somthing.
Old Feb 28, 2007 | 01:43 PM
no... you wouldn't if they were retarded several degrees but otherwise in sync. I'll betcha your cams aren't timed correctly. You should be making like 20+ more hp minimum.
Old Feb 28, 2007 | 07:40 PM
Post the graph if you can please.
Old Feb 28, 2007 | 07:44 PM
98-GT's Avatar
ok i'll try to post it tomorow night. Also if the timing is off a bit would this damage the car at all?
Old Mar 1, 2007 | 06:12 AM
Yeah i would still say the cam timing would have to be off for such low numbers.
Old Mar 1, 2007 | 10:02 AM
Wheat's Avatar
I'd like to see the graph, too. Stock PI engines typically peak the torque at 4000 RPM and power at 5000 RPM.
Old Mar 1, 2007 | 10:54 AM
98-GT's Avatar
i should have the graph up tonight
Old Mar 7, 2007 | 01:25 PM
Could result in bent valves.
Old Mar 10, 2007 | 09:55 PM
98-GT's Avatar
I finnally got to scan my dyno sheets, let me know what you guys think
File Type: jpg
File Type: jpg
Old Mar 10, 2007 | 10:02 PM
98-GT's Avatar
I cant seem to get the right size of that first one ill try to post it up again later
Old Mar 11, 2007 | 07:05 AM
Thats one of the worst a/f ratios i have ever seen. It should run right under 13:1 for best n/a power.
Old Mar 11, 2007 | 08:22 AM
big bad lean until 4K rpm. That's a proper maf transfer function away from a much better performance. I'd be surprised if it's not pinging at 3500rpm.
Old Mar 11, 2007 | 05:33 PM
I agree....could even run closer to 12:5 and bump up the timing
Old Mar 13, 2007 | 11:15 AM
98-GT's Avatar
so is that a/f somthing mechanical or is that in the tuning?
Old Mar 13, 2007 | 12:07 PM
there's exactly 1 way to "properly" tune air fuel ratios. That's the MAF transfer function. You tinker with that with a custom tune.
Old Mar 13, 2007 | 08:31 PM
http://forums.modulardepot.com/uploa...487d4a5cf6.jpg
Thats what your a/f should look like. Yours is terrible and thats why you're down on power. Find a new tuner.
Old Mar 14, 2007 | 09:48 AM
much better. Nice and smooth.
Old Mar 14, 2007 | 06:51 PM
98-GT's Avatar
so you guys dont think its the cam timing anymore? and does anyone know of any good tuners in NJ? I know JDM engineering is supposed to be good but they only tune 01 and up mustangs.
Old Mar 15, 2007 | 09:40 AM
Wheat's Avatar
Kevin@Wicked Motorsports is good; he's in Brick.
Old Mar 15, 2007 | 11:23 AM
Matt Hill @ www.matthillmotorsports.com is good.
Old Mar 16, 2007 | 01:00 PM
Wheat's Avatar
Yes, add him in.
Old Nov 11, 2007 | 06:53 AM
blueta's Avatar
I know this is an old post, but was that a/f AFTER a tune or was that just as you rolled it into the dyno?
Spoiled
Dyno Results
Jun 15, 2007 07:54 PM
MachGT
Dyno Results
Apr 4, 2006 07:56 PM
Dec 17, 2005 11:10 AM
cobra4123
Sep 9, 2005 08:42 PM
Treachery
Aug 26, 2005 08:57 PM
