lowering springs
Old Jan 22, 2007 | 03:38 PM
mustngspd's Avatar
Default lowering springs
how would i go about lowering my 98 mustang.
Old Jan 22, 2007 | 03:51 PM
getting a set of lowering springs....or cut your existing ones but your ride comfort will decline dramatically
Old Jan 22, 2007 | 07:57 PM
wrong section, moving...
you can do coil overs or just replace the stock springs with aftermarket ones. YOu will depending on the spring need new shocks and struts and also you might need caster camber plates.
Old Jan 22, 2007 | 09:34 PM
mustngspd's Avatar
im thinkin bout getting maxspeed springs, is that a good idea. they drop 2 inches in the front and 1.8 inches in the rear
Old Jan 23, 2007 | 08:33 AM
Never heard of them. I would stick w/ Eibach, H&R, or FRPP. Also, if you are going to drive your car daily, I wouldn't go more than 1.5".
Old Jan 23, 2007 | 10:33 AM
2 inches is too far a drop. You'll wreck the handling. 1.5 is as far as you should go till you do more extensive mods like coil overs/k-member/control-arms/etc...
Get a set of Maximum Motorsports CC plates and make your alignment guy happy. maxspeed sounds like ebay, which never really works out right. Steeda sports, H&R sports, FRPP B or F springs or an eibach kit.
You should also upgrade your shocks and struts. The stockers weren't designed to correctly dampen the added spring rate from the lowering springs and the drop will thrash them after a while.
Old Jan 23, 2007 | 12:53 PM
mustngspd's Avatar
thanks for all the input guys
Old Jan 24, 2007 | 01:32 PM
mustngspd's Avatar
i looked over another thread in this forum and saw how to install the lowering springs, but how do i install cc plates?
Old Jan 24, 2007 | 01:35 PM
the instructions that come with the Maximum Motorsports plates are very thorough and clear with pics of all the interesting parts.
The general processs is, jack up car, drill out pop rivets, remove strut top nut, drill hole #4, install plates, cinch down strut top nut, adjust alignment, enjoy.
Check out www.maximummotorsports.com and you can download a PDF of their instructions.
Old Jan 28, 2007 | 11:08 AM
mustangbullitt03's Avatar
Default springs
i like my stock springs
Scorpyo137
Apr 26, 2005 05:37 PM
BoBs
Apr 13, 2005 05:37 AM
WikidStang
Mar 2, 2005 06:52 AM
dmkx3
Dec 28, 2004 02:51 PM
98silvergt
Nov 21, 2004 10:06 PM
