Professional Products Plenum on my 96 GT
Old Jan 15, 2007 | 08:38 PM
stngmn96's Avatar
Default Professional Products Plenum on my 96 GT
Ok boys and girls, I have found something interesting about installing the Professional Products Intake Plenum. I put it on my 96 Gt today. While installing this thing I found some very unique problems with this. Motor background is such: Full PI swap, forged pistons (flat top), forged crank, mach 1 fly wheel and SCT tuned.
Now when installing this plenum, I found most things went well. The supplied brass fitting for the hoses are easy to get in, (first of many but's) but they only go so far in before they get way tight. Second thing I found was a possible problem was the hoses. The rear hose on the back of the plenum doesn't quite fit, but with a bit of fussing you can make it fit. The third and biggest problem I have found was my cold air intake fitting to this thing. I have a UPR intake and with the new plenum installed the all metal intake won't fit onto the throttle body. If you have the stock strut tower brace as I do, you won't be able to make it fit. However, aftermarket strut tower braces will likely work, or remove it completely. I had to use the stock rubber intake tube to fit it, and this thing still was a beast to fit.
I felt anyone who has this in the work should know of the issues I had with it. You will end up with two bolts from the original plenum left over. No issues I have found yet other than these three things.
Old Jan 16, 2007 | 04:18 PM
Buy a K&N FIPK or JLT RAI
Old Jan 16, 2007 | 06:20 PM
stngmn96's Avatar
The K&N is just way *** expensive. Where can I find the JLT RAI? Thanks.
Old Jan 17, 2007 | 05:43 AM
G PURE 260 STANG T's Avatar
I HEART MUSTANGS
i had all of those problems on my 02 gt it sucked but the product works great im happy with it if your looking for an intake ive heard good things about jlt but if money is an issue i got the 80 dollar one from american muscle. it works just fine
Old Jan 17, 2007 | 07:16 AM
I have the PP plenum, Steeda CAI and MM strut tower brace. It all fits... just barely. The tower brace will have to be redesigned when the 5.4 comes in... grrrr.
Old Jan 17, 2007 | 05:49 PM
stngmn96's Avatar
I have just the stock tower brace and I couldn't get it to fit for any reasonable way possible. I am thinking the C&L Intake tube from the throttle body to MAF since it is formed with bends would work. Not sure though.
Old Jan 18, 2007 | 02:13 PM
I couldn't get the C&L pipe to work on my setup even with the stock plenum. It hit the hell out of the STB. Kinda trial and error. If all else fails you can cut 1" from the TB side of the C&L pipe and that'll open up some clearance to the STB and the strut tower itself. It worked ok for me but I said screw it and used a steeda.
Old Jan 19, 2007 | 08:17 AM
stngmn96's Avatar
Thanks! Like I said, I have the UPR CAI and it wont fit for **** under the stock tower brace. I appreciate the feedback.
ace1_15
Sep 26, 2006 02:49 PM
r3dn3ck
SMACK Talk!
Mar 21, 2006 04:07 PM
dirtrider2242
Jan 15, 2006 10:47 AM
SDHeckler
Jul 8, 2005 06:01 AM
fast01gt
Jan 1, 2005 07:39 PM
