attn: MattJ
Old Jan 11, 2007 | 04:56 PM
Get rid of that stupid cap. its not doing anything but stealing power from an already power hungry setup. anytime your accessories are on like AC, heat, wipers, headlights, interior lights, ect... its drawing power.
I would also check what kind of voltage you are seeing before the cap. Take a multimeter and touch the end of the power wire, and the other to a ground, with the car running. You should see anywhere from 13.2v to 12.8v in an optimal setup. Im sure I see 4awg wiring so I dont think thats a problem.
Id also try cranking it up in your driveway and checking to see if your amp is going into protection, or if its totally losing power.
How long is your ground cable? It should be as short as possible, and if its not done, id sand the paint away from where its ground for a more solid connection.
Old Jan 11, 2007 | 05:48 PM
MattJ: Mustang Boards audio guru
Old Jan 12, 2007 | 04:20 PM
what kind of voltage is your amp seeing? try seeing if you can measure the voltage when its cutting out.
try unplugging your sub's amp and see if it still does it. im guessing its a voltage problem somewhere.
ChrisXoxide
31
Jan 31, 2006 07:36 PM
dannyb785
24
Nov 9, 2005 07:21 AM
swervo
Nov 6, 2005 06:27 AM
XLR8
Aug 15, 2005 06:31 PM
