Does the TOB have to be replaced immediately?
Old Jan 7, 2007 | 10:50 AM
eventer289's Avatar
Default Does the TOB have to be replaced immediately?
I know this topic is on here all the time, but I can't find a straight answer. Does the TOB have to be replaced right away? What happens if it is not addressed soon enough?
Thanks
Old Jan 7, 2007 | 11:59 AM
whats the "TOB"
Old Jan 7, 2007 | 12:04 PM
Throw Out Bearing? If so, those thngs can squeak forever and I would not worry about it. Replacing them cost about $450 from a shop in labor and often leak after the swap. Just wait until you want a new clutch.
Old Jan 7, 2007 | 12:15 PM
the worst that could happen is a bit of scoring on your input shaft to the tranny. That'd be really expensive to fix. Still...it takes a long while to get there and there have to be other factors to get that bad.
Do what I do... just put it in neutral and let the clutch out when you're not actively in gear. It takes a bit to get used to but it'll save that 450 bucks till it's clutch time. When you get a new one... get the all metal one. There's a thread here with the part you'll need... just search for TOB.
When you upgrade your clutch... the bearing gets replaced. Mine's been squeaking for like 3 months now. Not a lot... but when the tranny gets hot it does it.
Old Jan 7, 2007 | 03:29 PM
eventer289's Avatar
Yes, I normally sit in neutral at lights and things. The only thing is that when the tranny is cold, if I put the car in neutral as I am rolling it makes this god aweful sound like pea gravel in a blender. It goes away after it warms up, but on hot days it makes the loud squeaking sound once in a while.
Old Jan 7, 2007 | 04:31 PM
you need to have your clutch inspected. There's something definitely not right in there. You don't want to have a bigger problem. the whole gravel sound is a sign something may be going seriously wrong.
Your call but that's my advice to you.
Old Jan 7, 2007 | 07:22 PM
eventer289's Avatar
I had a ford tech I know in KC tell me that is was my TOB at a meet we were at. It goes away when it gets warm and it does sound like bad bearings so I am assuming it will be okay.
Old Jan 7, 2007 | 09:01 PM
What it could be is that when the engine warms up, the heat expands the cable letting pressure off your TOB. Try re-adjusting the cable to see if that helps. I know for mine there's a fine line between the clutch pedal vibrating and having the TOB squeal loud enough to hear above the 2,000 rpm drone.
Old Jan 7, 2007 | 09:41 PM
eventer289's Avatar
I've just decided I'm going to get it replaced and have a spec stage 1 installed while the tranny is off.
96TangerineBossGT
Jan 29, 2008 09:18 AM
wade95
23
Oct 23, 2006 12:45 PM
Joyrider564
Jan 18, 2006 08:30 AM
94StangGTVert
Nov 11, 2005 07:37 PM
madmatt
Oct 23, 2004 11:12 AM
