Tr3650 ?
Old Jan 4, 2007 | 03:34 PM
blackstallion's Avatar
Default Tr3650 ?
Hey i was wondering if anyone here knew off the top of their heads how much fluid the TR3650 takes my damn manual doesn't have the 3650 only the T-5 and T-45. I"m sure I can figure it out just don't want to have to make 10 trips to the store to get teh fluid... thanks
Old Jan 4, 2007 | 03:37 PM
3V2000GT's Avatar
46MONSTER
Im pretty sure it takes the same fluid as the t 45, because they basically the same trans
Old Jan 4, 2007 | 03:38 PM
i know what fluid type it takes its any auto trans fluid so i'm using the royal purple syncromax... but i was wondering on the quanity? sorry for the confusion
Old Jan 4, 2007 | 04:43 PM
IIRC the 3650 should take a gallon and change (4+qts).
Old Jan 4, 2007 | 04:46 PM
3.8 quarts
Old Jan 4, 2007 | 04:52 PM
thats pretty funny cause I found a spec where it said it took 8 pints/4 quarts. Thanks for the info
Old Jan 4, 2007 | 04:57 PM
steve-o's Avatar
look up the tsb for the 3650. I think if you do a search on the mach1 forums there is something about it on there. The tsb was for the fluid level in the 3650. I know that isn't much help but if you look it up, it is very specific on the type and amount of fluid. Good luck.
Old Jan 4, 2007 | 07:19 PM
http://www.bullittarchive.com/WebHel...0_Overview.htm
3.4 qts should do the trick. It won't hurt if you do fill it up to 4 qts (found out about the TSB after I did my change) but shifting into 2nd sometimes doesn't happen.
Old Jan 4, 2007 | 07:34 PM
Your car should take 3L of fluide with the new TSB to keep the noise down.
Old Jan 5, 2007 | 08:52 AM
Dustin is right....3L or 3.17 quarts. Call Tremec and they will tell you the same thing. If you want to have your tranny shift like a dream use the "sauce". I used this combo and the tranny is much much better.
https://mustangboards.com/general-te...h+Transmission
bassman97
Jul 20, 2009 09:02 PM
AussieTE50
Jan 8, 2008 03:15 AM
PureStang
Jun 21, 2007 07:12 PM
