MM&FF New Edge Cobra vs Mach 1 Shootout!
Old Jan 4, 2007 | 09:35 AM
Default MM&FF New Edge Cobra vs Mach 1 Shootout!
Well, it looks like the 99/01 Cobra vs 03/04 Mach 1 debate will be put to the test in a MM&FF shootout. Below is a thread that was posted on svtperformance and a similiar thread was posted on the mach 1 registry.
Apparently MM&FF will be releasing the rules in the near future, but I really hope they have different classes because once you start modding the two cars it's pretty hard to settle the debate because people on either side will cry about the other cars mods.
Any thoughts?
http://www.svtperformance.com/forums...d.php?t=349810
Old Jan 4, 2007 | 10:10 AM
04DarkShadowGT's Avatar
Mach 1s look better and I would rather have one than a 99 or 01 cobra by far.
A Mach 1 with a beefed up IRS would be perfect.
Old Jan 4, 2007 | 01:57 PM
TClark22's Avatar
Blown 2V
why would you want an IRS...solid ftw unless u want to handle good...but who wants that out of a stang?
i would take a mach over a 01 cobra anyday...they look better outside and in.
Old Jan 4, 2007 | 03:25 PM
New Edge's Avatar
hey take it easy on us irs, ugly interior/exterior car owners...
Old Jan 4, 2007 | 06:36 PM
I'd take a 01 cobra...........
Then drop a 03 cobra motor in it
Old Jan 4, 2007 | 07:00 PM
New Edge's Avatar
why? no point you might as well put on 03 motor in your gt,
Old Jan 4, 2007 | 07:23 PM
i would tahter have a 99 cobra and do the FR500 heads,cam,intake upgrades to it. and then spray the crap out of it.
Old Jan 4, 2007 | 07:27 PM
If i'm correct the fuel system in a 99 or 01 cobra is a retuen fuel system which a GT has a returnless. There are more parts such as the the tranny and driveshaft in the cobra that can be used for a 03 motor swap. A Cobra is a better choice to do this type of swap. In terms of less things to do it's easier than droping it into a GT.
Old Jan 5, 2007 | 05:49 AM
Alot people do, they sell tons of suspension upgrade stuff that is not for drag racing as well. The IRS is better for everything except drag racing. Not just handling, but it will ride better and not be as jarring over expansion joints or not get bent out of shape by hitting a pebble in a curve.
Old Jan 5, 2007 | 09:02 AM
I can't wait to read about this shoot out because this debate goes on constantly on several boards. I just MM&FF does it so differently than some of the other shootouts they've done in the past. They need to do stock for stock and then cars with pretty much the same mods. I'd like to also see a round where the MM&FF driver does tests on each car so the results are pretty consistant rather than guest drivers being all over the map. Just my two cents.....I just want to see what each car can do without a crappy driver screwing it up.
Old Jan 5, 2007 | 11:43 AM
So much bashing on IRS cobras... Fact of the matter is that until you spend a few grand on your rear end an IRS will outhandle a live axle and be more comfy to drive. That being said, once you've made the expensive mods to the live axle it'll handle waaaaay better than the IRS. I've done it... a couple times. The IRS launches way better on the street than it does on an improved track (I've seen an 03 cobra with DR's and skinnies lift the front wheels at launch on the street) but if you launch hard on the 1/4 mile tracks you might just snap a half shaft. I've snapped 2 on the street.
If you spend a few grand fixing all the problems wtih the IRS it's not a lot better than it was when you started. It'll be stronger and get less wheel hop but you have to go pretty far to make it really handle like a slot car and you still have nowhere near the rear grip of a torque arm setup.
I'd bet the machs will clean up. They all make more power stock than the 99-01 cobras did, they have solid axles and they weigh less. Cobras are nice but they're not the big fish in a little pond that they used to be. The mach is the new sherriff in town.
rkaz
Mustang Classifieds
May 18, 2010 09:59 AM
Ghostalker
Jan 26, 2009 03:13 PM
Rabbit
Sep 1, 2006 11:58 AM
CCM
May 14, 2006 08:54 AM
