347 for the winter project?
Old Nov 17, 2006 | 01:31 PM
94IVGT's Avatar
compcams04
Default 347 for the winter project?
ill be doing a 347 motor this winter for my stang but ive got a ????
do 347's burn oil like everybody says?????
and which rotating assemblies are the ones youd recommend??? eagle is a givin. it will be getting boosted next winter or late summer
Old Nov 18, 2006 | 05:39 PM
ClemsonStang's Avatar
a 347 is a motor just like anyother. just because of the bore and the stroke doesnt mean it will burn more oil. i could see how it will **** the piston alittle more, and let some stuff around the rings, so it is slightly possible. are you planning to use a stock block or an FMS block? that will depend most of the quality of the components you use. and how much boosted hp you wanna make.
Old Nov 18, 2006 | 06:21 PM
347's have that reputation because the pistons are shortened and that causes the piston pin bore to intersect the oil ring groove. Even with the neat little spacer that is supplied with those pistons that's supposed to fix that problem, they don't.
There are a few kits out there that use pistons which don't have the oil ring bisection issue. I'll have to look for the one I'm thinking of but IIRC it uses Diamond pistons and eagle rods on an eagle stroker crank.
To make any good power from a 347 you need much improved heads like AFR 185s. You don't want to go too big on the heads but definitely need better than e7 castings.
GerRrg281
44
Nov 18, 2007 08:26 AM
ClemsonStang
22
Jan 22, 2007 12:24 PM
97stanger
22
Nov 4, 2006 01:18 PM
roushrider81
Sep 14, 2006 04:55 PM
roushrider81
Sep 14, 2006 03:46 PM
