Help! Stripped bolt!
Old Nov 9, 2006 | 04:50 PM
markm's Avatar
Exclamation Help! Stripped bolt!
I'm putting brakes and rotors on the back of my 01 Stang. I finished the left side. Went to take of the right caliper and I stippped the lower 12mm bolt that holds caliper on. Yeah, I effffd it up good because I kept messing with it.
Does anyone know a trick to get a grip on it and break that sucker loose?
Maybe a tool from Sears. Thanks, Mark M
Old Nov 9, 2006 | 04:59 PM
Spray some PB Blaster or WD-40. Vise grips might work. Or you can try hammering a socket onto it, I think a 12 point would probably work better. If none of that works, you could try a Craftsman bolt out set.
Old Nov 9, 2006 | 05:00 PM
cobra1923's Avatar
pipe wrench
Old Nov 9, 2006 | 05:10 PM
markm's Avatar
Yes I tried the Vise Grips. That's what really messed it up. It kept slipping and rounding the edges. Usually the Visegrips work on everything!
I think I will try a 12 point socket, is that what your taliking about?
Do they make a piprwrench that small where it would fit down there?
Thanks for the tips, Mark M
Old Nov 9, 2006 | 05:35 PM
Yep.
Old Nov 9, 2006 | 06:17 PM
uh
easy outs
duh... available at sears hardware and other fine tool stores
Old Nov 9, 2006 | 06:36 PM
markm's Avatar
Yes Gregg, I'll probably get the easy outs. I was just fishing for something to try that I might have in the garage or something that I haven't tried. You didn't have to get stupid on me. I already know I messed the bolt up. Mark M It's all good!
Old Nov 9, 2006 | 06:42 PM
lol
well easy outs are what ya need... Ain't much else you can do...
If they don't work out comes the grinder and alot of PITA work lol
Old Nov 10, 2006 | 06:07 PM
markm's Avatar
OK guys, I found the,"Special tool"! Went to Sears and was dreading having to drill that nut out. I was looking around for a problem solver and I found it! NO GARAGE OR HOUSHOLD SHOULD BE WITHOUT ONE OF THESE KITS!
Here it is: Bolt out
Damaged Bolt/Nut
Remover Set
Obviously this won't work if the head has been broken off, but it will work on any stripped nut or bolt. These things are awesome. I'ts made by Craftsman and I think Bob Villa was selling these on TV sometime ago because on the packageing it says as seen on TV. I bought the sweet set of 13 pieces. I could have used one of these a long time ago.
Alright, so what should have taken me an hour or so to do the job, took me awhile longer because of my foul up. But that's normal when I'm wrenching on my car and I found some cool tools to add to my set in the garage. You can never have to many tools! I love em! Mark M Thanks D&D Garage!
Old Nov 10, 2006 | 06:09 PM
Glad you got it.
Old Nov 10, 2006 | 06:14 PM
markm's Avatar
Thanks D&D Garage! Mark M
Old Nov 10, 2006 | 06:49 PM
haha, no problem man. What exactly did you put on anyway?
Old Nov 10, 2006 | 10:32 PM
Fryrice's Avatar
Craftsman has a 10 piece bolt/nut remover set for $50 on sale. One of the best investments you will ever make . Made for stripped heads. It will get you outta many binds.
Old Nov 10, 2006 | 10:33 PM
Fryrice's Avatar
Originally Posted by GREG@SN95
uh
lol@ other fine tool stores .
Old Nov 10, 2006 | 10:52 PM
rebelyell's Avatar
More Cowbell
Glad you got it out. I deal with broken socket head bolts very often at work. It's best when it breaks the head all the way off. then use a carbide drill bit to drill all the way through it. A hardened bolt with any relief at all has a good chance of coming out. easy out extractor should do the trick. if not you can always chip away at the hardened bolt. It is very brittle, and can be busted up using a punch and hammer, with some TLC you can get that hardened bolt out. Just dont try too hard and mess up threads of the hole..
Old Nov 11, 2006 | 11:25 AM
markm's Avatar
I was putting on some drilled and slotted rotors and some high performance brake pads on. The rotors are nice with a zinc finish. They're just replacement size rotors that work with the original calipers. I got the four rotors and the two sets of brake pads for $200! Mark M
How do I post a picture of my car, say in this thread?
Old Nov 11, 2006 | 11:56 AM
I host my pictures on www.mustangmods.com then put it in threads by using the button yellow button with the mountain.
Old Nov 11, 2006 | 11:58 AM
Fryrice's Avatar
You gotta use your new bolt/nut remover set.
bigkeeko
Jun 19, 2011 08:22 PM
tigerfan2771
Sep 21, 2007 06:10 AM
dewman2004
Jun 24, 2006 06:55 PM
csledd
Jul 14, 2005 06:36 AM
jlw31289
Dec 26, 2004 03:02 PM
