Sparkplug Chang?
Old Oct 27, 2006 | 11:50 AM
DarkSith's Avatar
Victory Is Mine
Default Sparkplug Chang?
Can someone tell me how to change the sparkplugs in my car, you just pull the coilpack and then the spark plug is there right? What size extension to I need, ect... Also whats a good Sparkplug to replace mine with, should I just get some motorcaft ones?
Old Oct 27, 2006 | 12:14 PM
I went to Kragen and got a spark plug changing kit and it came with a 5/8" spark plug socket and extension. I would also get a cheap gapping tool because you can't assume the gap from the factory is correct....sometimes they get moved during shipping ect....
Pull wire/boot off spark plug.
Put spark plug socket over spark plug
Attach extension, attach ratchet
Remove spark plug
Then to install:
You rub a little dielectric grease on the end of the spark plug that the boot will attach to. Rub a little anti-sieze on the threads
Thread the spark plug back in. Do not overtighten!!!!!!!!! Check a manual to get the torque spec. Use a torque wrench to tighten.
Do one spark plug at a time so you don't mess up the plugs/wires - shouldn't be a problem anyway.
Old Oct 27, 2006 | 01:21 PM
What is done to your car? If it is N/A then go with stock Motorcraft plugs with a TINY bit of antiseize. If it is supercharged or has nitrous, then go with NGK TR6 plugs gapped at .035 and NO anitiseize. Antiseize or too much of it will not seal the plugs well enough for boost or spray.
Old Oct 27, 2006 | 08:32 PM
Who told you that? Kauffmans used anti-seize on my car and those guys know what they are doing.
Old Oct 28, 2006 | 11:12 AM
you use anti seize if you want to get them out easily next time. boost/spray should have nothing to do with it.
Old Oct 28, 2006 | 12:45 PM
You dont need anti seize on the threads. I dont use it, Tim @ Modular Powerhouse doesnt use it, and a lot of the members over there dont use it either. Torque them to 13 ft. lbs. Heres a good write up, http://www.bullittarchive.com/WebHel...ittArchive.htm just dont use anti seize.
http://www.modularpowerhouse.com/for...ht=spark+plugs
Old Oct 29, 2006 | 03:43 PM
aluminum heads, steel plugs... i use anti-seize.
Old Oct 29, 2006 | 03:55 PM
Exactly, I didnt have anti seize on the first plugs I put on went to take them out a year later and it sucked scaared the crap out of me because I thought I stripped the head threads
Old Oct 30, 2006 | 05:08 AM
Hate to say it but for the bullittarchive site, they recommend the use of antisieze. My 2¢ is that if it doesn't hurt the engine, you could only benefit from it so I say use it since it's cheap insurence.
Old Oct 30, 2006 | 06:33 AM
there's heat, electricity and differential metals all going on. I use antiseize cuz I don't want to chemically weld my plugs to the head. It doesn't happen a lot but it only takes the 1 time.
Old Oct 30, 2006 | 07:25 AM
it happend to me when i was helping the old man change plugs on his beater toyota truck
Old Oct 30, 2006 | 05:29 PM
Dan:
You have always been a trusted source of info, but you are about the only one I have ever heard that says no antiseize.
Old Oct 30, 2006 | 05:32 PM
BTW, anyone know what a torque wrench costs?
Old Oct 30, 2006 | 08:39 PM
Depends on what you want. A cheap-o Craftsman version can go for $60 while a good S-K or Snap-On piece goes for $200-300. In addition, capacity and type makes a difference in price.
Old Oct 30, 2006 | 08:45 PM
$19 for a good one at sears.....free if you return it after your done....
Old Oct 31, 2006 | 03:20 AM
littledonko's Avatar
Antiseize FTW!
Old Oct 31, 2006 | 11:35 AM
Dan:
Im the only one here that says you dont need it. Will it hurt, probably not. But like I said, the guys at MPH dont use it, so I dont think its needed.
Old Oct 31, 2006 | 12:46 PM
blackstang00's Avatar
00 GT V8 Stock. I was thinking about using Bosch platinum. I've heard their excellent. When I modify my stang I might use something else but in the mean time are those good enough.
Old Oct 31, 2006 | 12:57 PM
word of advice bosch sucks...all their products with exception to O2 sensors. I would never use their spark plugs. Autolites,motorcrafts, and my personal choice NGK are all I will use
Old Oct 31, 2006 | 12:59 PM
What are the price range on NGK's?
Old Oct 31, 2006 | 01:03 PM
ernest russell's Avatar
Smile
your car came with motorcraft platinum awsf 32p i put autolite platinum apt64 and gao them at 54th. always use antiseze alum. steel you will have problems
Old Oct 31, 2006 | 01:10 PM
OK Thanks I'll go with the Autolights. I've heard before that they where good plugs. I've got a convertible to. I just love mine it's my second conv. First stang.
What are the price range on N&K's?
no more than $16-17 for 8 plugs
Old Oct 31, 2006 | 01:18 PM
good pick ap764 gap at 54th
Old Nov 1, 2006 | 09:07 PM
Fryrice's Avatar
On top of that,make sure the motor is cool when you try and pull the plugs. The aluminum swells and can make it hard to pull them ..
And they are NGK's.
99_GT
Jul 6, 2007 01:06 PM
bruce99cobra
Nov 2, 2005 07:38 PM
