top end support
Old Oct 22, 2006 | 08:06 PM
94IVGT's Avatar
compcams04
Default top end support
hey, i am looking for a part that you install in the lifter valley to stiffen up the top end. i forgot the name and if anybody knows where to purchase it at that would be great.
Old Oct 22, 2006 | 09:07 PM
the lifter dog bone?
Old Oct 23, 2006 | 07:50 AM
94IVGT's Avatar
compcams04
does it bolt into place to hold the upper part of the block from cracking under high power?
Old Oct 23, 2006 | 10:16 AM
go to horsepowertv.com (part of powerblocktv.com) and check it out there. They just had a show about that yesterday. they always advertise their test parts in the hot parts section.
It's stiffens the lifter valley of the block which is still called bottom end despite its placement at the top of the bottom end... the "top end" is the heads and valve train.
Old Oct 23, 2006 | 10:35 AM
94IVGT's Avatar
compcams04
hey thanks, i thought i have seen it somewhere. i looked on their website but cant seem to find it.
Old Oct 23, 2006 | 10:41 AM
I'll see if I can dig it up for you.
Old Oct 23, 2006 | 10:57 AM
not listed yet. call up the powerblock and see if they can point you at it.
Old Oct 23, 2006 | 12:02 PM
ah a lifter valley girdle then. Good show summit racing carries though still i belive.
Old Oct 23, 2006 | 12:24 PM
they're like a girdle but it's a 3 piece set that I saw on HPtv. Requires drilling .75" deep holes in the block and tapping in some roll pins. I don't like the design... I think it fails at one key part of the windsor block flexie break problem... twisting. If there's a single piece solution that helps control twisting I think that would be better. ANybody ever seen such a thing?
Old Oct 23, 2006 | 12:44 PM
94IVGT's Avatar
compcams04
thanks, ive found them through www.horsepowersales.net
they claim it greatly strengthens the block, but i dont see how with 3 small screws????? it doesnt seem possible by there setup. any other opinions???
Old Oct 23, 2006 | 01:18 PM
if it could be welded on I think it might be really helpful but since it's using roll pins at the ends and a single small screw in the middle... I don't think it'll help much. Still anything is better than nothing. Really only useful for siamese bore 5.0's making over 500hp. I say instead of wasting money on band-aids why not fix the problem with a FRPP R block, World products block or a Dart block. hell even a mexican block should be stronger.
Old Oct 30, 2006 | 06:33 PM
cobra331's Avatar
should be two screws (maybe im wrong), but the screws arent for support, they are for indexing and placement. its job is to prevent twisting and give support to the valley, the valley is jus a big open hole really, and this bridges that. but i agree with the above. if you have that much power, buy a racing block!
Old Oct 31, 2006 | 08:18 AM
way true... having seen a 5.0 come apart I can tell you that a racing block is worth its weight in gold if you're over 500rwhp. When a windsor cracks in half it's shocking to say the least and usually destroys the rotating assembly.
The one I saw on the powerblock was a single screw in the valley and a roll pin on each side by the head. Could be multiple designs... never can tell.
karsons3.8
Nov 18, 2008 02:29 AM
1Fast92FiveOh
Jun 2, 2007 10:16 AM
Aug 26, 2005 02:34 PM
04 STANG
Aug 1, 2005 02:14 PM
