soo maybe getting twins
Old Sep 11, 2007 | 09:21 PM
SxyXc's Avatar
Default soo maybe getting twins
OK, so my friend was searching a junk yard, and found some twin turbos of a totaled car, he bought them for like $5 because the fans where broken, He said that he almost has them fixed and will give em to me.
but i have a couple questions. If i get em i will only run about 6-8# because i don't want to blow my block.
but what else will i need?? an intercooler, BOV, pipes, new headers for turbos, bigger maf. biger injectors (can the maf and injectors wait??) a tuner and a tune. but what about suspension. I really don't have the money to go and get a new suspension do i really need one?? also do i have to have a boost gauge or can i run w/o one??
If i get them i will post up some pics. wish me luck on getting them though. and if i do get them it should be around this weekend
Old Sep 11, 2007 | 09:28 PM
oohsoobad2's Avatar
Sounds like you want to attempt a DIY twin turbo setup. It can be done but you are going to need alot of parts besides the turbos. An aftermarket K member will make the job much much easier. Id wait til you can afford one before you start.
I wouldnt attempt this unless you have a welder on hand and are pretty good with it. Also plan on lots of downtime for your car as this will be an complex project to say the least.
Good luck !! Keeps us updated and take lots pf pics...
Old Sep 11, 2007 | 09:48 PM
SxyXc's Avatar
would it work to try to go to a place that sells turbo kits, and try to talk to them about just buying everything but the turbo?? or would it be better to sell the turbos when i get them and try to save for a whole kit that comes witht eh k member and suspension
Old Sep 11, 2007 | 10:09 PM
oohsoobad2's Avatar
Buying a kit would be the best way to do it but not the most affordable.
Check out this site for some good tech, I think a few guys have turbos with stock K members.
http://www.theturboforums.com/smf/index.php?board=32.0
If I was going to attempt it, Id start with headers from this guy...
http://www.turbochargedinnovation.com/products.htm
Old Sep 12, 2007 | 08:02 AM
mpt_1962's Avatar
just buy the kit like he said.
Old Sep 12, 2007 | 03:59 PM
go with hellion, may take awhile to save for it but will be well worth it in the end.....
Old Sep 12, 2007 | 08:31 PM
SxyXc's Avatar
if they are nioce turbos how much do yall think i can get for them if i sell em on something like e-bay??
Old Sep 12, 2007 | 08:40 PM
depends on if they have standard straight discharge on the intake and exhaust sides. Also it would be good if the exhaust flange was something you could mount a downpipe to.....It will need to be something valuable for someone looking to build a kit. They probably arent, but it would be awesome if they were external wastegate......I say price on ebay could range from $100-500 for junkyard pieces that have been cleaned up and rebuilt.....
Old Sep 12, 2007 | 09:08 PM
SxyXc's Avatar
ok, when i get them i will tell yall more about them, and show yall some pictures...
Old Sep 13, 2007 | 03:05 PM
if you have any welding and mechanical knowledge its not hard to fab up a single turbo setup. It takes more time to plan it out and find all the parts you need them welding up the pipes and making it fit (thats where planning comes in).
Old Sep 13, 2007 | 03:43 PM
SxyXc's Avatar
what would i have to do for a twin set up if wanted?? i was kinda thinking about looking at the routing i need for something like this,
i don't think it would be too hard, only have to find a way to get the exhuast back to the back, and the rest i think i may be a ble to do..
or do yall have any good ways i can get a single turbo set up, i want somewhere around the 300+RWHP on about 6-7# of boost
Old Sep 13, 2007 | 05:42 PM
A home done twin setup would be alot hard and alot more parts then a single and a stock short block doesnt need twins cause you cant even get the full benifit of them. A nice DIY single is what i wanna do once i get a welder and some time to plan it all out.
That setup you like is a nice and setup and will be a pain in the *** to setup diy style.
Old Sep 13, 2007 | 05:57 PM
SxyXc's Avatar
so if i remeber correctly the turbo's i will be getting are atleast 57mm, what all is needed to get a single turbo set up? also i would like to keep it as simple as possible, where should i put hte turbo, between the engine and radiator?
Old Sep 13, 2007 | 06:55 PM
you need to just put the turbos at the end of the tailpipes and run some charge piping up to the front with an oil pump and intercooler. That would be the easiest way.
swervo
Jun 14, 2008 09:18 PM
StreetRacer
Jan 14, 2008 05:40 PM
swervo
Aug 23, 2007 09:32 PM
PureStang
Tire and Wheel Talk!
Jun 29, 2006 09:21 AM
Aug 28, 2005 12:23 PM
