ABS Light comes on!
Old Sep 8, 2007 | 09:52 PM
03_GT's Avatar
Smoke Tires....Not Drugs.
Default ABS Light comes on!
Ok, I had a bolt in my front passanger tire, and i was 45 min away from home, Well thinkin i could make i didnt, The bolt came out and the tire went falt, well i pulled off the side of the highway to get the spare out of the trunk, Ok so the spare was on and 5 min after driving with the spare the ABS light decides to come on, well the next day i got all the tires replaced on the car and now when i drive from point A to point B the ABS light still comes on, What do you think could cause this malfunction? The tire did not sread up, i pluged it and used it that night, Cant pick up girls with a spare tire on the stang . Let me know what yall think, Thanks!
Old Sep 8, 2007 | 11:33 PM
mpt_1962's Avatar
mine did that when i had a blow out...after a few days the light quit coming on. I had the spare on for a day or two but once i got the tires replaced it was ok.
Old Sep 9, 2007 | 07:01 AM
03_GT's Avatar
I had all the tires replaced but it still comes on.
Old Sep 9, 2007 | 07:03 AM
Check your sensors to see if they are alright (if they broke or they are covered in metal shaving).
Old Sep 9, 2007 | 09:20 AM
03_GT's Avatar
Where can i find this sensor? Im not to familer with a ABS System!
Old Sep 9, 2007 | 09:46 AM
For the front: Look towards the front of the spindle and look for a tiny cylinder that is located barely above what looks like a gear.
Once you find it up front, you'll know where to look in the rear since it's similar, w/o the spindle.
Old Sep 9, 2007 | 10:44 AM
03_GT's Avatar
Gotcha, Thanks!
Old Sep 10, 2007 | 11:21 AM
'02SilverBullet's Avatar
My ABS light started comming on once and I didnt know WTF was goin on... no flats, no nothing! After a bit of investigating I found out I was low on brake fluid. I filled it up and unhooked the batt for a min to reset the ABS light and it was done! I havnt seen it since! Just a lil something to check for as easy as it is to do that!
Old Sep 10, 2007 | 12:08 PM
krazypony's Avatar
I was gonna suggest unhooking your battery, for about 30-45min and then back up as mentioned above.
I had this happening on my 2000 Explorer, but it was my engine light coming on and got it checked out and everyone said it was running lean, so once I unhooked the battery it seemed to go away without any problems and has been off for almost 6-8months.
Old Sep 10, 2007 | 12:34 PM
your emergency brake light comes on when your brake fluid is low
Old Sep 11, 2007 | 08:32 AM
Opps Now that ya mention it.... you are correct! I was wrong. I think I had my time frame off a bit in my head cuz I had a busted hose causing a vacume leak making my engine light come on that very same week that I filled my brake fluid. Disconnecting the batt did nothing for the brake light (just the simple fill and it was off). The batt thing DID do the trick on making the engine light go off after I fixed my hose.
My apoligies!
Old Sep 11, 2007 | 07:37 PM
03_GT's Avatar
It was low on the brake fluid, i put some in and reflashed to the computer and the light is still comming on, I guess tomorrow im gonna pull the tire off and see if i see anything worng!
batplus4
Apr 19, 2010 12:34 PM
IceMan
Feb 23, 2006 04:42 PM
HollywoodGT
Feb 9, 2006 11:02 PM
mgar22
Jun 30, 2005 01:50 PM
Lances03SVT
Jun 29, 2005 01:39 PM
