what size injectors? 36lb too much?
Old Sep 6, 2007 | 01:47 PM
blackstallion25's Avatar
Cool what size injectors? 36lb too much?
so for those who dont know or forgot i have an 01 gt mods:block bored 30 over forged pistons rods ported heads stg2 cams new valves valve springs full exhaust full bolt ons. i know that on the 01 gt they only have 19 pound injectors my buddy has 36lb injectors for sale is that too much injector for my setup or what size injector should i go with thanks
Old Sep 6, 2007 | 02:07 PM
24lb should suffice.
Old Sep 6, 2007 | 10:40 PM
mpt_1962's Avatar
the 01 Gt's have 21lb injectors right?
Old Sep 7, 2007 | 07:07 AM
Your tuner wont have a problem making the 36's work, unless he has absolutely NO idea what hes doing. Too much injector is a lot better then too little.
Ask your tuner.
Old Sep 7, 2007 | 07:23 AM
The 02-04 have pink ones which they say are 22# injectors, but some say they are just recolored 19#ers. I have yet to see some hard evidence on if they are really 22#ers or just 19# ones.
Old Sep 7, 2007 | 07:56 AM
mpt_1962's Avatar
how would you be able to tell? What about when someone is tuning your car...do they have to factor in the injector size? Are there any tuners on here that would know the lb?
Old Sep 7, 2007 | 08:19 AM
Shouldn't be any 01's with 21/22's. There might be a couple late production 01's but I've never seen one.
Ask your tuner.
to a point yeah but drivability and mileage can suffer if he doesn't trim the slope right.
evidence would come in the form of a smoked motor. If you take out he pink tops and put in the yellow tops you'll run it hella lean. The adaptive controls should figure it out but not probably before engine damage.
See above. I tune my own car with SCT software. There are pre-fabbed injector slope value files available for the various tuning softwares. SCT includes them with theirs. Once you've got the correct file loaded then you can move on to MAF xfer tinkerings and the rest of the process.
Your tuner knows on sight if he's done this enough times.
Old Sep 7, 2007 | 08:42 AM
mpt_1962's Avatar
Well...guess that sums up this thread. Red how old are you? You know ALOT about...well...ALOT. Good info! Might have to have you check my tuning on my car when we have the GTG if you can bring a laptop and your software. I have a SCT Xcal-2. I could definately use your knowledge on the tuning part. I'm nervous about getting my car tuned for the first time. But i could definately buy you some food or something when we have the GTG for your time.
Old Sep 7, 2007 | 09:55 AM
I can only look at the file but your tuner is better equipped than me to judge his work.
I'm... old.
Old Sep 7, 2007 | 12:15 PM
bossman302's Avatar
I just want to add that my 2002 GT has 19# (yellow tops). So not all 2002's will have 21/22's
Old Sep 7, 2007 | 12:23 PM
now that I have seen. Tell me... does your MAF sensor have 4 wires going into it or 6?
LMK... I've been collecting info on that.
Old Sep 7, 2007 | 07:05 PM
what??????????
Old Sep 7, 2007 | 07:22 PM
bossman302's Avatar
I hope you have seen this since my car was in your drive way My MAF has 6 wires.
what??????????
Yes, my car has 19# injectors. My water pump is also the long version. Go figure
Old Sep 7, 2007 | 09:10 PM
I guess the bigger question might be "why do you need bigger ones?". I might be inclined to buy them if the price is right and just hold on to them until you are making enough power. Slapping on bigger injectors and paying for a tune really won't net you more power unless your tune was not right to begin with OR your current injectors are too small.
Old Sep 8, 2007 | 07:33 AM
i think 19lb injectors are a lil small for my fully built setup
Old Sep 8, 2007 | 08:34 AM
he's looking at 300rwhp on the high side... 19's are at the last few percent of their duty cycle making 365 engine hp. 21/22 pink tops are ok but I'd skip em and go to 24's for a bunch of reasons.
Remember, the rating of injector volume is for a specific pressure. If you don't know what you'll need then you can have your tuner tell you. If you're using a handheld then you can leave some leeway in the tune for a 2nd injector slope and upgrade if you find they're sliding up close to 100% duty cycle at WOT.
Old Sep 8, 2007 | 08:35 AM
just like a bigger jets in a given size carb aren't always needed, bigger injectors aren't always the right thing.
Wait till the tune. you don't have run those 19's to fully 100%
Old Sep 8, 2007 | 08:46 AM
mpt_1962's Avatar
yeah i was told to wait until i get heads to change the injectors. I have VT stage 2 cams and they dont pull enough to swap out the injectors yet. I was told to wait until after i get the heads to even think about the 24's.
Old Sep 8, 2007 | 11:35 AM
i was thinkin about 30 lb? is that too much or should i just get the 24lb
Old Sep 8, 2007 | 12:56 PM
rada's Avatar
<---- Injector N00b...
Juat ran out an looked at my injectors - they're orange... Are they all color-coded to a certain poundage?
Are these stock?
Old Sep 8, 2007 | 07:32 PM
mpt_1962's Avatar
not sure what orange is...but just go with the 24's blackstallion.
Old Sep 8, 2007 | 08:07 PM
Are these stock?
There color coded and orange is stock 19#ers.
Old Sep 9, 2007 | 07:30 PM
thanks guys now do i need or should i buy a bigger maf to go with it i just have the stocker
Old Sep 10, 2007 | 08:06 AM
you'll only ever need to contemplate a bigger maf when you add boost. You're still NA it would seem so no. You'll never need one unless that changes.
Stang Kang
Feb 20, 2010 02:52 PM
Bwhipple
24
Jan 9, 2007 07:33 PM
SpinMedia
Oct 22, 2006 07:09 PM
omegared3915
Mar 31, 2005 06:05 AM
ItSaGiRlStAnG
22
Dec 7, 2004 03:09 PM
