Dyno Results Post your actual dyono results here for all to view.
Roush Dyno
Old Sep 7, 2007 | 03:50 PM
macj47's Avatar
Default Roush Dyno
So first off I'll give you the specs on the engine.
Ford motorsports block with a full VT Engine assembly: Cobra crank, Manley H Beam rods, Diamond 19CC pistons, Moly Rings, Patriot Stage 3 heads with Comp Cams 278 cams, ARP Head/Main studs, ARP Rod Bolts, FRPP Dampner, ARP Dampner bolt. Vortech V2 polished supercharger, 3.60 and 2.85 pulleys, Reichard Racing aluminum 2 piece intake manifold, 75mm throttle body, NGK V2 plugs, 5.4 coil paks, 03 Cobra pumps with Kenne Bell boost-a-pump, FRPP shortie Headers, UPR O/R X pipe, flowmaster mufflers. Cobra oil pump, 180* thermostat.
Then the specs on the tranny..
Tremec T56 6 speed transmission with the upgraded, hardend 26 spline input shaft. Also have installed a brand new Spec Stage 3 clutch kit with new throwout bearing and pilot bearing, Cobra Aluminum driveshaft, crossmemeber, Adjustable clutch cable and quadrant. Cobra pinion flange. Ok so with all that I had it dyno tuned at 432.6HP @ 10psi. I also have the front mount intercooler to put on, 60lb injectors and 15psi pulleys... When I get those put on I'm expecting as much as 650HP to the wheels. Should be pretty sweet...
Old Sep 7, 2007 | 06:54 PM
This section is for dyno sheets and numbers.
Old Sep 8, 2007 | 12:56 PM
S trim to 650 horsepower not likely....a guy with similar setup made like 580 hp and 530 tq that was with a cooler and NX cooler shot.
Old Sep 12, 2007 | 08:11 AM
sheet?
Apr 7, 2008 10:38 AM
Markstung70
Jun 23, 2007 09:31 AM
May 7, 2007 11:39 AM
BadMoFo
Sep 20, 2006 06:34 AM
venom
Dec 23, 2004 11:58 PM
