2000 GT Oil Gauge on cold start problem
Old Aug 28, 2007 | 11:23 AM
donw35's Avatar
Default 2000 GT Oil Gauge on cold start problem
Found the TSB for it, does anyone know the resolution ?
TSB #14907
CONCERNS WITH VEHICLES EXHIBITING THE OIL PRESSURE GAUGE REGISTERING LOW OR NO OIL PRESSURE USUALLY ON INITIAL START-UP AFTER SEVERAL HOURS OF COLD SOAK. *TT (NHTSA ID #620221, MAY 01 2001)
Old Aug 28, 2007 | 02:31 PM
New oil pressure sender. I suggest getting an Autometer gauge as well since the stock one really only tells you when the car is on or off.
Old Aug 28, 2007 | 02:55 PM
96blackgt54's Avatar
STUPID GAUGE!
That is the case! My engine would be off at idle!
Old Aug 28, 2007 | 03:22 PM
ericgutz's Avatar
Oil pressure sender. Had the same problem on my 00 GT. If i remember right, it's about 10 -15$ at ford dealerships.
Old Aug 29, 2007 | 12:23 PM
donw35's Avatar
How hard is it to replace ? and what is the location of the sender on the motor.. Thanks
Old Aug 29, 2007 | 01:24 PM
Fairly easy to replace. The send is located on the oil filter mount on the block (look for electrical lines going into that area).
Old Aug 29, 2007 | 02:20 PM
ericgutz's Avatar
Yeah, it's right by the oil filter. You might as well change the oil while you're at it because the oil is going to leak out when you're swapping the oil sender anyway.
Old Aug 29, 2007 | 09:43 PM
mpt_1962's Avatar
but how do you add another oil gauge in the mix? You cant unplug the stock one because it will throw off the computer right? So how do you plug in a mechanical guage?
Old Aug 30, 2007 | 06:30 AM
There is a port right under the stock oil pressure sending unit. You take the metal plug out and install the aftermarket sender for the aftermarket gauge. Very easy to do.
The only guages i have are Fuel pressure (for my nitrous kit) and oil pressure along wiht nitrous pressure one on the bottle too.
Old Aug 30, 2007 | 06:52 AM
You could also use a T-fitting if there's room.
jfc2000gt
New Members!
Feb 9, 2015 11:33 PM
3.8LMustang
Jun 23, 2008 08:33 PM
NJ6fan
Dec 29, 2007 08:44 AM
NJ6fan
Dec 28, 2007 04:52 AM
1988 5.0
Jul 2, 2007 12:22 PM
