Raditor Fluid Leaking....
Old Aug 26, 2007 | 07:22 PM
stage2roush2002's Avatar
Roush #6147
Default Raditor Fluid Leaking....
All of my radiator fluid leaked out while I was driving my '99 GT. No clue where from. I checked the hoses, and everything was great. Any ideas?
Old Aug 26, 2007 | 07:27 PM
Is it leaking on the ground, or is there an internal leak?
Old Aug 26, 2007 | 08:58 PM
yellowstang99's Avatar
35th Anniversary GT
Is the drain valve on the bottom of the radiator closed? Maybe it worked loose and let everything run out...
Old Aug 27, 2007 | 01:33 AM
Ironwarrior's Avatar
You need to fill it back up and try to determine where it's leaking... Is the water pump circulating? Is the motor getting hot?
Old Aug 27, 2007 | 04:34 AM
Roush #6147
It leaks everything. It overheated on my way home and I to stop and have someone pick me up. I later went back with a pitcher of water and barley made it home. I cant really tell where it is leaking because there is radiator fluid all over the motor too.
**I bottomed out before this happened, but I do that alot.
Old Aug 27, 2007 | 08:00 AM
overheat = mucho bad. Find the leak... bad WP maybe. No bottoming out either... jeebus.
Old Sep 8, 2007 | 01:40 PM
Barry Tichenor's Avatar
If the coolant is all over your motor, it sounds like your manifold coolant crossover is leaking.
Old Sep 8, 2007 | 02:04 PM
Roush #6147
Thanks yall, but I sold her.....sadly.
But the problem was that the intake manifold cracked.
Old Sep 9, 2007 | 06:14 AM
That is a common problem that someone did a class action lawsuit and won. Ford had to reinburst or fix this issue for free. Anyone that has the plastic crossover tube should replace the intake before it cracks.
doobie
Oct 3, 2008 08:55 PM
jareds98gt
Sep 25, 2007 08:03 AM
jeredan2003
Jul 19, 2006 04:03 PM
May 8, 2006 10:54 PM
venom
Nov 22, 2004 05:43 AM
