06 GT
Old Aug 25, 2007 | 01:21 AM
charles's Avatar
Default 06 GT
I have a 06 GT that I have installed shorty headers, cold air intake and 62mm throttle body, all from BBK. When I installed the throttle body a few days back I also installed a performance tune for 87 octane with my diablosport. Is the perfromance tune good enough to keep my engine happy with the changes I have made? My concern is leaning out the motor. Should I be using a different tune? Some time soon I will be installing 4.10 gears and might install NOS. Any suggestions?
Old Aug 25, 2007 | 03:44 AM
chrisblkmustang's Avatar
Your tune from diablosport will be fine just as long as you enter all the upgrades you listed into your tune. I would put in a 93 tune for more power at the track (if you go). Your best bet is to go to a dyno shop and have them do a custom to so that they can play with you air/fuel ratio. Also get a air/fuel gauge if you want to make sure that you are in a safe range at all times. This really isnt too nessary but if your going to add any kind of power adder (nitrous,supercharger,etc) then I would get you a a/f gauge.
Old Aug 25, 2007 | 10:40 AM
you need to jump on a dyno and make sure all is well with the AF. You're letting more air in than before. May need a little fuel curve adjustment. I've never been happy with a Diablo tune out of the box. Goo ruck.
