bad timing chain tensioner cause ticking noise?
Old Aug 3, 2007 | 10:31 PM
32vRacer's Avatar
Default bad timing chain tensioner cause ticking noise?
was told i had a possible bad timing chain tensioner. heres the deal, when car is started up cold very noticeable ticking until warms up and idles at 1k or 900. also when driving above 1800 rpm ticking comes back, seems like faster with higher rpms. any1 know what the hours is on tthat job?
Old Aug 11, 2007 | 02:31 PM
32vRacer's Avatar
possibly BS than?
Old Aug 11, 2007 | 02:59 PM
the chain tensioner doesnt make any noises and doesnt even touch the timing chain. Its just there to hold up the chain guides that put tension on the chains. Sounds like some other issue your having....
Old Aug 11, 2007 | 03:51 PM
machnjo's Avatar
Here's a pic of a failed tensioner arm. It did cause alot of problems with my engine, but there wasn't a ticking noise. The right bank tensioner arm is kinda notorious for failing.
Old Aug 12, 2007 | 11:13 AM
it's entirely probable that you have a sticky lash adjuster. Try running a quart of ATF in your oil for a few minutes before your next oil change. That may loosen up the crud. That ticking can come from a lot of places.
Old Aug 12, 2007 | 03:10 PM
32vRacer's Avatar
a quart of ATF? is that safe?
Old Aug 13, 2007 | 08:13 AM
don't run it for days or nothin... just a few minutes at idle right before the change. I'm sure there's a few others on the board old enough to have used the procedure before. I've done it hundreds of times.
Don't overfill your oil... drain a quart first if your oil isn't low.
Old Aug 13, 2007 | 06:36 PM
32vRacer's Avatar
Default car just lost it all!!
my car lost everything. has no *****, not even acelleration. is thats how u spell it. it wont go. just gets really loud racing in rpms but drives slower than ****. suddenly happened, any ideas. reverse is the only gear the didtn **** up. trans???? happened after doing a burnout. i heard something about a rev limiter, once u hit it ur car runs shitty til code is cleared? maybe i was high when i heard it though. no check engine light either, this whole time....
Old Aug 14, 2007 | 08:12 AM
tranny = fragged. get another.
32vRacer
Nov 19, 2007 08:17 AM
mpt_1962
Jun 11, 2007 05:16 AM
NewMustang
Dec 17, 2006 05:46 PM
solja4jc
Nov 13, 2006 12:15 AM
04oxfordgt
Jun 29, 2006 09:12 AM
