started spring install...
Old Aug 2, 2007 | 06:25 AM
theponyfactor's Avatar
Default started spring install...
i put the rears in last night and it didnt look any lower im going to do the fronts within the next few days and then check it out, might be taking it apart again.
There was a rubber tube thing in the stock spring just sitting there, what is it? and do i need it? just seemed pointless sitting in there.
Old Aug 2, 2007 | 07:07 AM
krazypony's Avatar
those are called isolators
Old Aug 2, 2007 | 07:12 AM
not the isolater...unless there is three of em. there was a rubber tube inside the spring, not on the coils.
Old Aug 2, 2007 | 04:51 PM
If you want to lower it 1/4 more than dont use any isolator. You need to drive the car around to let the suspension settle down. Get the biggest friends you have and go for a ride.
Old Aug 3, 2007 | 06:17 AM
ya im probably going to take the back apart again tomorrow night when i have some time again. hopefully it will be done by monday.
anyone know of a write up where they use spring compressors? a guy i work with has some and he's gettin them for me...
Old Aug 3, 2007 | 08:11 AM
IceMan's Avatar
Yellow C5 Z06
Yeah those rubber tube things I always see with drag kits. I don't know what they are but I know what you're talking about.
-B
Old Aug 3, 2007 | 10:16 AM
'02SilverBullet's Avatar
Ya dont need a spring compressor at all. I done mine not long ago and front and rears came out w/o a prob. Since ya got the rears figured out , on the front... after ya got it up on jack stands, take your jack and raise the A arm a bit just enough to put pressure on the spring. Disconnect the tie rod and lower the jack. A pry bar and a tad bit of muscle will free the front springs pretty dang easy.
Old Aug 3, 2007 | 11:04 AM
i know you dont need one, but i had always heard it helped. plus i didnt want to have to hammer out the tie rod end or w/e you have to do.
Old Aug 3, 2007 | 11:29 AM
The tie rod was super simple. I just used a deep socket 15mm I think was the size. On the lower side of the A arm where the rod conects I droped a nut, had to get a wrench on the top side too to keep it from spinning. In fact, I have to admitt that suspension is not my thing. I didnt disconect the tie rod it was the sway bar. There was a small verticle rod that had blue rubber bushings on it (I dont know what the name of it is)But I disconected THAT rod on the bottom where it went through the A arm. After that nut drops off the bottom end of that verticle rod the whole A arm assemble will lower fully and take all the pressure off the spring. Considering you unbolted the factory CC plates under the hood.
Do a search on these forums I found a link somebody posted to D&D garage and they had a complete walk through with pics. Thats what I used, and I say its a pretty nice write up!
As you can tell I know nothing bout suspensions and that walk through made things super simple. I hope ya find it, and GL with the project!
Old Aug 3, 2007 | 11:32 AM
ya i know what write up you're talking about. ill go read through it again
Old Aug 3, 2007 | 11:56 AM
Best write up out there IMO. http://www.dndgarage.net/springinstall.htm
Old Aug 6, 2007 | 07:54 PM
does the taking off the tie rod make much of a difference when you lower the control arm? I have everything else off and i lowered the arm to try and put the new spring in and it just wont go. so will the tie rod make enough difference to get the spring in?
Old Aug 6, 2007 | 08:57 PM
Yes, just follow the instructions. That write up is the easiest way to change springs, trust me.
Old Aug 7, 2007 | 06:03 AM
i took everything else off (except tie rod) and the control arm lowered a lot, i just needed like an inch more to get the spring in...i guess ill hammer it out tonight.
it doesnt help that my dad doesnt have any confidence in doing this type of stuff to a car and when i mentioned hammer it out he didnt like that at all.
Old Aug 7, 2007 | 06:35 AM
I have done it 10xs without removing the tie rods. I used pry bar to get spring out once the control arm is lowered. You can remove tie rod and it will be easier to get spring out but the tire rod is sometimes hard to remove.
Old Aug 7, 2007 | 06:40 AM
i got the spring out, i just cant push in the new one. i can get it close, but i cant get it in.
Old Aug 7, 2007 | 07:21 AM
Make sure that the car is high enough so control arm goes down as far as it can and you can use the pry bar to get it back in if you need to.
Old Aug 7, 2007 | 08:30 AM
2kids3pets's Avatar
williteverend
What springs did you get
Try some lube on the front ISOs to help slide them in...pry bar helps
Old Aug 7, 2007 | 08:54 AM
i got h&r sports.
and i almost got them in without the bottom iso...with it in would be even harder.
Old Aug 7, 2007 | 01:51 PM
are the mach 1 struts like an inch shorter then the stock ones? when had put one in (with the stock spring still) i couldnt get the strut to come through the cc plate enough to even get the nut on. will it be a lot different with the h&rs?
also should i lower the car down first before i put the strut nut on so it pushes the strut up as far as it will go?
Old Aug 7, 2007 | 03:36 PM
heres a pic...everything on this side is bolted in...
Old Aug 7, 2007 | 04:17 PM
That may be due to the camber plate but what I did is remove the two bolts the hold the strut to spindle so I did not mess with anything up top.
Old Aug 7, 2007 | 06:47 PM
well i put the top in first on the driver side and i dont see how im going to be able to line the holes on the bottom up. if i use the jack, it just starts raising the car
Old Aug 7, 2007 | 07:14 PM
What holes are you talking about the ones for the strut, two bolts that attach to the spindle? Im not sure why it difficult but here is all I took apart to get springs in and out. Brake caliper,two strut bolts and endlink nut, thats it.
Old Aug 7, 2007 | 08:17 PM
ya those holes on the strut in your pic, 2 of them. i put the top of the strut through the plate with the spaces from MM. then when i jacked up the control arm until it started lifting the car i still had about an inch until the holes would line up on the strut and the spindle i guess...the holes that it bolts too off the caliper. i have everything installed, i just cant get the holes to line up.
now that i think about it maybe i can just put some of the spacers that are on top to the bottom.
Old Aug 8, 2007 | 06:39 AM
Dont tighten up the bolt until you have both of them in. You may have to raise or lower control arm plus move it around so two holes line up. Also make sure that the coil end or bottom pigtail of spring is correctily inside the perch. I put a piece of tape to mark where the perch ends.
Old Aug 9, 2007 | 06:07 AM
well i have been talking to MM and we still can't figure it out. I sent in pictures and they suggested a few things which helped, but didnt solve the problem.
Old Aug 12, 2007 | 02:53 PM
Ironwarrior's Avatar
I had no problem lining up my strut bolt holes.
Make sure the cup of your floor jack is just in front of the spring (toward the outer edge). You have to straighten the Rotor and position the jack up next to it so the cup is on the end of the A-arm. When you lift the jack you can watch the spring compressing. Make sure the top isolator is oriented properly and the pigtail of the lower spring between the 2 holes (1 hole should be exposed). The spring should be compressed enough before it gets to the point where it is raising the car if you have the jack positioned properly. Maybe you are not getting enough lift from that small jack you are using.. Try positioning a couple small 2x4 pieces of wood under the cups....
If your not able to get the spring out then you don't have the car lifted high enough to allow the a-arm to drop low enough. Mine was up on the top of a pair of 6 ton jack stands position under the front of my subframe connectors.
The a-arm dropped low enough. The isolators where a little stuck to the bottom of the a-arm. I just pulled on them and twisted and they came right out. You can spray a little wd40 in there to help free them...
cobra1923
Dec 20, 2006 02:55 PM
toolttime
60
Jan 4, 2006 07:16 PM
swervo
Oct 21, 2005 11:10 PM
Han Solo
The Reference Section
Feb 1, 2005 07:34 AM
WaterDR
Feb 1, 2005 07:16 AM
