Cobra brake kit
Old Jul 24, 2007 | 08:22 PM
redfire04's Avatar
Redfire GT
Default Cobra brake kit
After spending some time reading up on the cobra brake conversion I've run across a couple questions. Please keep in mind this would be for a daily driver with no track use. I'm going to be needing new brakes soon anyways so I figure I might as well upgrade.
I couldn't find much information about the stainless steel brake lines. I'm thinking that I'm not going to get them but I wanted some input.
Also the kit on AM doesn't say anything about new banjo bolts. Do I need to pick these up seperately or do they come in the kit?
Thanks.
Old Jul 25, 2007 | 06:09 AM
They come with the banjo bolts. Id suggest getting the stainless braided lines. Brake lines expand and crack over time causing failure or a mushy petal.
Old Jul 25, 2007 | 06:28 AM
cobra1923's Avatar
Def do the stainless lines.... I personally feel they add more to solid pedal feel than the actual brakes did.. now the cobra brakes don't fade after coming down from 100MPH like the stockers
Old Jul 26, 2007 | 04:42 PM
redfire04's Avatar
Redfire GT
Thanks for the responses. Now I'm sure about the banjo bolts but I'm still undecided on the ss brake lines. The stock brake lines are not ss and I would imagine the will last for a descent amount of time. I have visited the track only once since I had my car so I won't be pushing these brakes to the limit by any means. It seems to me like the stock lines would be fine for my application. I just want something that will perform better than stock since I'm going to need new pads and the rotors turned anyways.
Old Jul 26, 2007 | 04:57 PM
00blkstanggt's Avatar
Hot, Nasty, Bad ass speed
I wouldn't get the kit through AM. For $399 you can get the kit from buyfordracing.com and it comes with the ss lines. Thats what I'm gonna do once I decide to buy the kit.
Old Jul 26, 2007 | 06:39 PM
Yeah, and they sent me the wrong lines.
Old Jul 26, 2007 | 07:16 PM
blownstang's Avatar
I got the kit through AM and used the rubber lines that came with it. Then i found out about buyfordracing. Get the kit from buyfordracing. I think it already comes with ss lines. As for the brakes, not as big as a difference as you would expect. The brake pedal still feels the same as it did with the stockers.
Old Jul 26, 2007 | 07:29 PM
blownstang's Avatar
wow, thats strange...I felt a big difference. pedal feels much more solid...brakes fell easier to control. did you do a brake flush after you installed them?
I just bled the fronts and the master cylinder. When I was bleeding them, the peddle was rock solid, but when I started the car and took it for a spin, the peddle became softer and mushy. If I push down hard enough the pedal will go to the floor, and I could feel it pulsing.
Old Jul 26, 2007 | 08:31 PM
hotshot13422's Avatar
That is very bad. I would definatly bleed your system again or take it to a professional
Old Jul 26, 2007 | 08:49 PM
running a 245 or 255 your not gonna see to much of a stopping differnece. My car has the abs kicking in real hard once i swapped out to good pads and stainless lines. I cant imagne how much the cobra kit with 245 tires would be locking up. If i had like a 9" wide front wheel and 275's up front i bet the braking power could really be used well.
Old Jul 26, 2007 | 08:50 PM
blownstang's Avatar
That never happens during normal driving though. I just wanted to see if the pedal will go to the floor if I push it hard enough and it does (this was done while the car was at a stand still). I guess I could have the whole system bled when I have my longtubes installed at the end of August. So far I haven't had any problems with the brakes since I put them on in April.
Old Jul 27, 2007 | 10:12 PM
redfire04's Avatar
Redfire GT
Thanks for the info about buyfordracing.com, too bad AM doesn't do that. I like buying from AM as I have a few times before they are good and fast. Oh well maybe they will put them in the August sale!
Old Jul 28, 2007 | 09:25 AM
caballo's Avatar
Exceptional Member
That's where I bought mine from just a couple months ago. They were/are great. Easy install. EVERYTHING fit perfect. Took me an hour to do both sides... +/-
Old Jul 28, 2007 | 09:30 AM
redfire04's Avatar
Redfire GT
I'm probably going to order mine from there too. Did that kit come with banjo bolts? It doesn't say anything about them on the website.
Old Jul 28, 2007 | 09:33 AM
caballo's Avatar
Exceptional Member
I was worried about that 2 days after I ordered the kit so I ordered just the banjo bolts. They called me and emailed me and told me that ordering them was a "waste of money" because they were included with the stainless lines(goodrich) that come with the kit.
StangMan04
Sep 14, 2007 09:04 PM
MAD SAMURAI
Oct 5, 2006 05:37 PM
steve-o
Apr 14, 2006 07:48 AM
whitethunder46
Jan 3, 2006 01:08 PM
yeayea0
Aug 16, 2005 12:38 PM
