1988 5.0L wont start when cold
Old Jun 27, 2007 | 10:22 PM
1988 5.0's Avatar
Default 1988 5.0L wont start when cold
when the car is cold it takes a hile to start and when it dose start it will backfire when the car is warm it will start fine but id if u take the car past 3500 rpm it will fall on its face it has been convt to mass air i have put ford racing 9 mm wire on it msd cap and rotor new plugs timing is at 12 derges i run 89 in it all the time any help would be great
Old Jun 29, 2007 | 09:05 AM
cobra1923's Avatar
This is one that is going to take some searching.
When you set the timing, you did take out the little "pill" module hanging on the distributor? The timing needs to be set without the computer automatically adjusting it, removing the module makes it static
Are you getting fuel pressure when it's cold?
Could be the "MAF conversion" MAF sensor, O2 sensor, TPS or IAC?
Vacuum leaks could be causing some issue but it would usually start and then run rough if that were it
First visually look around and make sure there are no sensors unplugged
Then turn the ignition to "on" but don't start the car, hit the schrader valve on the fuel rail (put a rag or something down in front of it) gas should shoot out with about 40# of pressure so be careful. If it dribbles or nothing, then you have a fuel filter, fuel pump or fuel pickup problem
Those 5.0 injectors seem to foul up pretty easy, shouldn't cause major problems like what yuou have but I used to get mine professionally cleaned out once a year (until I just upgraded to some 30# when I got the SC)
then I would plug a code reader in and see if your computer has any codes and go from there
Old Jun 29, 2007 | 11:03 AM
1988 5.0's Avatar
when i set my timing i did pull out the plug by the distributor i will have to check the fuel pressure i did see 1 vacuum line that looks pretty rough all the sensors r plugged in i was goin to go buy a new fuel filter today i know when i unplugged the the mass air meter it has thottle response so i dont know if it is the mass air flow cause if it is i am goin to put a new mass air flow and probley 24lbs injectors in it thank i will put a new post when i find out some more
Old Jul 1, 2007 | 03:11 PM
1988 5.0's Avatar
i put new plugs in it and a new fuel filter it is a little better but i still falls on her face at baout 3500 rpm
Old Jul 2, 2007 | 10:46 AM
cobra1923's Avatar
something def not right, check and make sure your intake track is tight (especially from the MAF to the intake). The dying out after 3500 could be fuel issue, do you have an adj regulator, might try tweaking it a bit to see if has any effect
Old Jul 2, 2007 | 12:22 PM
1988 5.0's Avatar
i dont have an adjustable one but the 1 that is on there just got replaced when i took the 4 banger out and put a 50 in
rtaylor15
30
Apr 10, 2008 09:46 AM
rtaylor15
Apr 6, 2008 04:23 PM
96MustangGT
16
Feb 25, 2007 08:16 AM
bigdog1011972005
Nov 9, 2005 08:52 PM
Bodyman23
Apr 20, 2005 09:51 AM
