Drag Racing! Discussions on drag racing, using the tree and techniques for improving your performance at the track
Going all out DRAG setup!!
Old Jun 19, 2007 | 05:28 PM
Talking Going all out DRAG setup!!
I need the front wheels off the ground! Heres what im planning on starting with.....4:10's with 31 spline axles, Eibach Drag springs all around, Lakewood 90/10 front struts, Strange 10 way adjustable rear shocks, 26x10x15 ET Streets, Lose the swaybar, Full length MM subframe connectors, and MM antiroll bar.
Sound good? Any suggestions? Oh and this is a daily driver......
Old Jun 19, 2007 | 05:56 PM
be careful driving that thing in corners. Too aggressive in the wrong way for a DD IMO.
I could also go with some nice adjustable front struts. May be a better option...
Old Jun 19, 2007 | 06:37 PM
WATCH OUT FOR THE PEOPLE HAVING SEX AT TEH DRAG STRIP
I wouldnt doubt it! I might have to pull out a can of whoop ***!
Old Jun 20, 2007 | 01:07 AM
jeds'91_stang's Avatar
upper and lower rear controll arms, and take as much weight out of the front end as you can that will help to get the wheels pointed skyward. I dont know about 94 and newer stangs but the fox cars have a nasty habbit of tearing out the torque boxes so you might want to look in to renforcing those as well.
Old Jun 20, 2007 | 07:40 AM
Thats a good solid drag setup but its gonna suck on the street i would for sure go with adjustable front struts too so you can make them stifffer so its ok on the streets.
Old Jun 23, 2007 | 06:37 AM
idk bout losin' the sway bar for a DD car. i think i'd keep it.
Old Jun 23, 2007 | 04:01 PM
well it looks like the drag setup will be put off for awhile.....differential is burnt up. I already took the swaybar off but will probably put it back on tomorrow.....
3.8LMustang
Drag Racing!
May 14, 2008 09:00 AM
simbill
Nov 8, 2006 11:07 PM
stang00
Oct 6, 2006 09:14 PM
shad0ws
57
Jul 7, 2006 08:28 AM
dannyb785
Mar 18, 2006 11:19 PM
