I'm Out Of Ideas
Old Jun 7, 2007 | 04:09 PM
theponyfactor's Avatar
Default I'm Out Of Ideas
As you know my car pulls to the right when I drive. Braking doesn't make it any worse so I assume it's not that. So I put the stock tires on and it didn't to it, so I figured that eliminated the back two. Now I put the front tires on backwards (directional) because I read that if you do that and it pulls the other way that you definitely have a tire problem. Well it seemed to pull in the same direction (right) even worse than before....I really can't buy all new tires, so I don't know what to do anymore.
Old Jun 7, 2007 | 04:27 PM
you have 9438098432 threads regarding the same subject. if you go back and re-read them a couple more times, im sure the problem is explained somewhere in there.
Old Jun 7, 2007 | 05:31 PM
fine so delete this one
Old Jun 7, 2007 | 06:26 PM
ya it was aligned. i guess ill just have to keep driving it like it is until i can get some c/c plates.
no i didnt get it aligned at a different shop
Old Jun 7, 2007 | 07:20 PM
r1ckyb0nd's Avatar
I did not read all the last postes about this problem nor am I going to search for them,
If lowered.
Did you buy new springs or just cut the stock ones.
How much lower is it now.
does you tire spin freely when jacked in the air.
Old Jun 7, 2007 | 10:51 PM
It's not lowered, and yes they spin fine.
I still have the papers on the alignment if that would help anything. They never mentioned anything though...
Mug11
Dec 14, 2005 07:17 AM
SINFUL XEPTNCE
May 17, 2005 11:03 PM
stang00
Mar 24, 2005 12:43 PM
TonyStangs
27
Feb 22, 2005 03:40 PM
offdwall
Jan 15, 2005 04:47 PM
