low rpm misfire
Old May 25, 2007 | 02:48 PM
NCredneck's Avatar
Default low rpm misfire
Are there any other idiots like myself who have taken there stang and washed the engine? I had terrible misfires afterwards and a low rpm misfire remains with a short stall when dumping the throttle. Any ideas about what in the f**K I have done?
Old May 25, 2007 | 03:00 PM
I'm pretty sure there is another member on this site that washed his engine and messed it up....I think I know who it is, but I won't out him. Hopefully he will chime in
Old May 25, 2007 | 03:42 PM
SleepingGT's Avatar
put in quad platinums they will cause the car to work in zero gravity
Old May 27, 2007 | 08:18 PM
suckinit's Avatar
I tried degreasing my engine, and ****ed it up....car was running real rough, I figured it was just water that would work it self out. The car kept misfiring all over and was blinking my check engine light...I tried changing the plugs and it didn't help....Turns out one of my coils shorted. Replaced the faulty, along with my boots because they were looking rough, and all was better. Check for water down in the plug wells too.
Worst part of it all was my engine bay still looked like ****
Old May 27, 2007 | 08:43 PM
Yeppers if you wash your engine htis can happen (i still wash mine) but if it does happen its nothing some air from an compressor or leaf blower can dry off. If that doesnt work pull the plugs and check for water in the holes.
Old May 27, 2007 | 09:31 PM
NCredneck's Avatar
Thanx, I'll check the coil and plugs for water. I hope it is that simple.
Old May 30, 2007 | 03:31 PM
stngmn96's Avatar
I have done this a few times. Don't feel bad. I think we all have. Like they have said, blow everything out, dry the plugs off if needed (have had to do this) recheck everything and run the motor till warm for a little while. Solves the problem most of the time. Good luck!
Old Jun 7, 2007 | 06:34 PM
NCredneck's Avatar
Well, for anybody else out there like me, if you wash your engine and have bad misfires without computer codes or SES to show, change the plugs. I don't know why, but it fixed the problem.
Old Jun 7, 2007 | 07:38 PM
jason keller's Avatar
Thumbs down ford f150
i did it with my truck but not the stang dude, what u thinkin
Old Jun 8, 2007 | 11:02 AM
WhitePony's Avatar
I just use that foaming crap from autozone, and yeah in the directions it says to cover the coil and any electrical connectors. i just put plastic wrap on top of them and when i wash it off with the hose i dont blast it, just shower it. Never had a problem
Old Jun 10, 2007 | 06:19 PM
blackstang01's Avatar
i had the same problem after washing under the hood. my advice would be to change the plugs, hell it doesn't hurt
p3s7_01
Apr 5, 2012 04:51 PM
SuperItalian
Jun 12, 2007 06:51 PM
MineralGT
Apr 20, 2005 05:30 AM
Raging Stallion
Apr 18, 2005 04:37 PM
aria
Apr 13, 2005 11:55 AM
