Old May 29, 2007 | 11:50 AM
  #1801
i never ran a alt bracket for the two years i had the first 5.4 but with this one being built to flog will get one. i'll just make a custom one.
Old May 29, 2007 | 12:19 PM
  #1802
2Eighty1's Avatar
Here is an interesting read I found while looking for info on the Aussie 3v 5.4 intake.
4.6 vs 5.4 - 5.4 owners point of view
Old May 29, 2007 | 02:41 PM
  #1803
VOID's Avatar
Totaly pimpalicious 5.42v
O ok cool. I don't think it should be that much of a problem, maybe when i get the plates ill have a piece of aluminum cut to the same hight as the plates and get it put between there to work
Old May 29, 2007 | 03:10 PM
  #1804
I would easily consider a multi-stage 300 shot. Just not all 300 at once. I'd probably start off with 150, then stage in two more 75hp hits. If you hit much harder than that you'll have massive problems blowing the tires off.
Old May 29, 2007 | 03:34 PM
  #1805
SleepingGT's Avatar
i looked into the 5.4 4v swap alot, some claim that the aussie heads are updated R's and some claim that they are 03/04's i've seen credible sources saying both(leaning towards updated R's but not sure), and contrary to what is commonly said, 03 navigators did not come with 03/04 cobra heads, all navi motors came with the extra large itnake port navi heads
Old May 29, 2007 | 03:49 PM
  #1806
SleepingGT's Avatar
i planned on 150 of the line nozle and 2nd stage 200+ second gear direct port
Old May 29, 2007 | 04:04 PM
  #1807
VOID's Avatar
sounds complicated , i'm just going strait up 12:1 Cr with a 150 shot. i don't know about that nozzle thing though, that thing is bank, but maybe i can get a trick flow intake.... should be nice.
Old May 30, 2007 | 11:37 AM
  #1808
VOID's Avatar
Hey guys, if i'm getting a whole 5.4 2v will I have any problems with the oil pan or should i use my 4.6 pan??? will that work?
Ok so, when i get this 5.4 what all will i need to get it to work.
I know that i will need plates and someone to hook the exaust up. But will i need to have it tuned or what?
One other question, the best cam for torque on this motor is the stock pi cam right? Thanks guys.
Old May 30, 2007 | 11:57 AM
  #1809
use your 4.6 pan. You'll have to bend a couple baffles a little to keep them from hitting the crank. no biggie..
you'll need plates, exahust work, a custom tune and 24lb or bigger injectors if you're planning on a bigger cam.
I'd go with a bigger cam...like a Vt stage 1 or a comp xe270. It'll have plenty of torque and better hp numbers. A xe262 would work as well. Either is likely to increase torqe with the kinds of charge velocities the 5.4 generates. The stock cams are a comprimise that doesn't do as much good for hp and tq as it could.
Old May 30, 2007 | 11:59 AM
  #1810
12:1 is too high for a street motor unless you plan on using race gas forever. I'd stop at 11:1. Trust me... you'll hate 12:1. if it's a race car, then 12:1 and nitrous will please you.
Old May 30, 2007 | 12:21 PM
  #1811
2Eighty1's Avatar
Does this need to be done on all 4.6 pans including aftermarket ?
Should the baffles be removed instead ? Also what about a 4.6 windage tray will that be a problem with the larger crank ?
Old May 30, 2007 | 12:35 PM
  #1812
dunno... on the aftermarket pans. if you're doing an aftermarket pan you should pony up for the aftermarket windage tray. I've seen a 4.6 FRPP tray adapted to the 5.4 but I don't know if it needed major modification or not.
Old May 30, 2007 | 01:28 PM
  #1813
VOID's Avatar
Thats something i would like to know, that big crank hitting oil seems like a bad combo. yea maybe 11:1 would be ok. What kinda cc piston am i looking at for that? like a 3cc or something?
Old May 30, 2007 | 02:37 PM
  #1814
2Eighty1's Avatar
I guess I'm going to have to look into that when i buy the tray and pan.
FWIW I got a call today, I definatly need to bore .20 over on my block, so I'll be shipping my pistons and rings back to MMR and waiting for the new ones.
So now that the motor will be a 333 CID engine, I was thinking HALFEVL for a custom licence plate (333 is half of 666). Could also be a reference to the whole sleeper thing or how timid the modulars are as daily drivers. Could also be funny to have the whole 5.4L (well 5.5L now) reference infront of everyones face and them not get it.
Old May 30, 2007 | 02:52 PM
  #1815
flat tops with stock PI heads and standard bore gets you 11.1:1. I'm using -4.5cc dish and getting 10.5 out of it and room for lots more valve lift if I ever decide to go that way.
I like it... that's clever. With the 20 overbore you'll raise the compression about .2 ... FYI. That may require a different dish depending on your application.
Old May 30, 2007 | 03:07 PM
  #1816
2Eighty1's Avatar
Raise the compression? So from 8.0 I should bump up to 8.2ish ?
I'm curious just how far you can mil the heads without the timing chains getting bitchy. I don't care about the intake, or the PTV since I have plenty of room for both - but those timing chains make me nervous.
Old May 30, 2007 | 03:24 PM
  #1817
don't mill the heads... if they're good you shouldn't need to.
yeah, when you add bore or stroke you increase compression ratio as a side effect. If you have 8:1 with your current dish size choice (fill me in and I'll double check for you) then you can expect to see 8.2 with that same dish size on a .020" overbore.
Old May 30, 2007 | 03:27 PM
  #1818
2Eighty1's Avatar
18CC dish on a 3v head (I believe they were about 51CC stock).
Should be 8:1 on a 5.4 3V and 8.5:1 on a 5.4 2v if I remember correct.
Old May 30, 2007 | 03:33 PM
  #1819
at those ratios .2 isn't jack to fret over. You'll be fine even with gross amounts of boost.
Old May 30, 2007 | 04:19 PM
  #1820
2Eighty1's Avatar
Figuired as much. It was either 18CC and 8:1 or 14CC and about 8.5:1 on the 3v but I got a great deal on the 18's.
Old May 30, 2007 | 05:38 PM
  #1821
VOID's Avatar
that sounds pretty cool. I was thinking though that when you boar it over then the cr goes down not up, but i could and probably am totaly wrong ,
The reason i asked about the 3 cc ones was that i got a set of cobra pistons that are 3 cc dished and i possibly are going to use them but who knows.
Old May 30, 2007 | 08:40 PM
  #1822
i bought a frpp windage tray and on the 5.4 the crank smacks it on the rotation. so i bent them out alittle to clear the crank rotation. if u look closely u can see where i bent it slightly.
Attached Thumbnails Anyone intrested in 5.4L swaps, in here. Need you to opine.-dsc01824.jpg
Old May 30, 2007 | 09:14 PM
  #1823
VOID's Avatar
so the pan won't pust that thing back into the way of the crank will it? and it looks like you just nudged the end closes to the end of the block. is that it?
Old May 30, 2007 | 10:01 PM
  #1824
the scrapers were hitting the crank so i bent them out so there was about 2mm of clearence...
Old May 31, 2007 | 12:58 PM
  #1825
VOID's Avatar
o ok so there is no worry about them hitting the crank now? do they work like the baffles in the pan? or how does thatwork?
Old May 31, 2007 | 01:21 PM
  #1826
2Eighty1's Avatar
Can/should the baffles in the pan be removed?
At their location I dont really see a point, being as the sump is in the rear, and with a windage tray the oil should be off the crank anyhow.
Old May 31, 2007 | 01:44 PM
  #1827
they're there as much for anti-slosh as for windage. bend em' but leave em in. Looks like I'll be using my FRPP windage tray unless someone can tell me they want to buy it... make offer. It's just exactly like myillwill's
Old May 31, 2007 | 05:03 PM
  #1828
on the stock oil pan u will need to bend the baffles alittle.
Old May 31, 2007 | 07:41 PM
  #1829
VOID's Avatar
cool dude, isn't the ford windage tray only like 40 bucks.
Old May 31, 2007 | 08:57 PM
  #1830
I dunno... I got it with a bunch of other parts so it cost me basically nothing.
