PCV Valve Problem
Old May 27, 2007 | 03:29 PM
02GTCONVERT's Avatar
Default PCV Valve Problem
Hi All,
I have a 2002 GT its having problems starting takes two to three times before it will stay on I have read all post on IAC and I will change it soon but I have noticed that the Hose going to the PCV Valve is collaped when it is Idling when I rev the engine alittle the hose opens...could the PCV valve cause the starting problem?...the car runs fine when it finally starts.
Any Help would be great thanks.
Old May 27, 2007 | 03:34 PM
The hose could certainly be your problem. There is so much vaccum that a standard type heater hose will not work. From the factory all of our cars come with a plastic tube from the pcv valve to the intake. Someone must have taken yours off and replaced with heater hose. You should just go to the ford dealer and buy a new plastic tube. Should be pretty cheap. Do this quickly as its not good to run your car all the time with that hose sucked closed. Only other thing that will work is a hose that has a steel coil spring inside to keep it from collapsing, autozone doesnt have these parts.
Old May 27, 2007 | 08:40 PM
Could be the PCV valve is trashed and needs to be replaced as if its failed or failing (IE getting stuck closed/open) I could see that hose problem happing. Could this be why it starts weird? no way it has anything to do with that. Its nothing more then sucking vaccum so it wont matter if the valve is stickying (what it sounds like hose wise) or working it will still pull vaccum so it wont effect starting.
Old May 28, 2007 | 02:51 AM
NoKturnaL's Avatar
Moderator
Just get a New PCV valve from FORD....also..you wanna get the Hose assembly for the PCV valve...the part # is 2L2Z-6A664-BA
Old May 28, 2007 | 08:07 AM
Default PCV Valve
Ok I am going to get the new Pcv valve and hose from ford and give that a try. I just got this car about three week ago...another thing I have noticed is when I acceclrate I can hear a hissing sound coming from the dash or engine compartment. Thanks for the info on the PCV Valve.
Old May 28, 2007 | 11:59 AM
NoKturnaL's Avatar
Moderator
um...what kind of intake do you have and did you JUST have it installed........Aftermarket intakes do make HISSING sounds...
Old May 29, 2007 | 06:21 PM
Default Intake
The Intake Looks Stock....But I did find a Receipt in the glove box that states that the intake was ported and polished. there is also a receipt for a Diablo Chip and programming service......also does anyone know about how much the IAC Valve is?.....I tried cleaning it but the car still has problems starting...also is this a dealer part or can i get it at a parts store?
Old May 29, 2007 | 06:29 PM
Default PCV Valve
Also on the PCV Valve it does have a plastic hose from the intake all the way until about four inches from the PCV valve then it turns into a rubber hose and that is the one that is collapsing I took the PCV valve off and shook it the check valve does rattle and the valve is clean.....should that rubber hose be a plastic one too?
Old May 30, 2007 | 12:08 AM
NoKturnaL's Avatar
Moderator
hmm..imm ahave to look at mines and see what mines has..I will let you know soon...I to is replacing my whole PCV setup soon.
Old May 30, 2007 | 05:31 AM
IAC is @$69.00 thru us, DO NOT BUY aftermarket
just because a PCV valve rattles, doesn't mean squat. a PCV valve should be changed @30k.
2002 uses a special PCV valve and hose that you'll have toget from a dealer(or us)
Old May 30, 2007 | 06:36 PM
im pretty sure that all our cars should have plastic all the way to the valve. At least thats how mine is.
Old May 31, 2007 | 05:16 AM
no there is a rubber elbow at each end of the plastic hose thats only comes wth the asbly
03GTMan
Apr 11, 2007 05:22 AM
super96stang
Feb 5, 2007 05:43 PM
El Diablo
Oct 7, 2006 12:11 AM
02gtpit
May 16, 2006 12:19 PM
PureStang
Oct 31, 2005 12:52 PM
