Need To Fix!!
Old May 8, 2007 | 10:12 PM
89-stang's Avatar
Default Need To Fix!!
ok i have an 89 lx and when im just cruisen along at about 2-3 rpms the hole car vibrates like crazy so i have to shift wut could it be cause ive been in another fox and it is smooth the hole time i dont understand why my car is doin this need it fixed want to be able to rev it up in gear not just shift thru fast
Old May 9, 2007 | 06:05 AM
Does it do it at every gear? Could be your driveshaft ujoints are bad.
Old May 9, 2007 | 03:44 PM
89-stang's Avatar
yes everygear
Old May 9, 2007 | 07:43 PM
Check driveshaft ujoint jack up car and wiggle the driveshaft where it meets up with the yoke. .
Old May 9, 2007 | 09:13 PM
89-stang's Avatar
ya i did that and its all fine
Old May 18, 2007 | 10:25 PM
Sounds like its starving for fuel...
Check your timing, check the injectors, check cap n rotor, check plugs n wires...
Run some fuel injector cleaner...
It may be a good idea to just replace the plugs cap and rotor all together...
Old May 31, 2007 | 12:25 PM
HellRaizer's Avatar
Loose or really worn out motor mounts?
Old May 31, 2007 | 01:59 PM
bossnutt's Avatar
Start with something simply, check your alignment and the balancing of your tires. Our 90 GT would vibrate like that, and found out the tires weren't balanced correctly.
04MustangGT
Nov 8, 2006 10:58 AM
PureStang
Oct 6, 2006 07:41 PM
stage2roush2002
Sep 24, 2006 02:36 PM
venom
Aug 5, 2006 04:02 PM
