Old Apr 25, 2007 | 05:29 AM
  #1591
blackbullitt5583's Avatar
Is that the typhoon intake?
Old Apr 25, 2007 | 06:55 AM
  #1592
That's the HPS intake. The Typhoon is nothing more than an Aluminum copy of the stocker that in most cases, makes less power than the stocker.
Also, when Motor Trend put the 00 R on the dyno, it made 376 hp and 386 ft*lbs. However, it was rated at 385 hp and ft*lbs. So, that thing made something like 400+ hp. The only disadvantage w/ 4V heads is size. The 4.6 is already a squeeze, a 5.4 2V a tighter one, and a 5.4 4V, well, you get the idea. However, 3V and 4V are the best match for the larger 5.4 but because of price, most of us are settleing on ported 2V.
Old Apr 25, 2007 | 08:57 AM
  #1593
The typhoon doesn't have the plenum volume I wanted for my combo. I like bassman decided on the ported and cammed 2v route, partly out of packaging concerns (tight fit already) but mostly because it's super simple to do the 2v with adapter plates.
My HPS intake has been heavily ported. There's still a bunch more finish work to do on it but I've kinda lagged on that. I've taken out more than 10 fl.oz of material and port matched from the heads to the plates to the intake.
Old Apr 25, 2007 | 09:01 AM
  #1594
Yeah, my impatience is going to delay me since my Hooker Headers took a good chunk out of my budget w/ all the problems I had. However, if I can get a decent paying job this summer, I may be able to start by next year.
Old Apr 25, 2007 | 09:32 AM
  #1595
VOID's Avatar
Totaly pimpalicious 5.42v
that is pretty cool r3d, i think i'm going to eventually go with the trick flow intake, i just love how it looks.
I've read that the 4v will fit but bairly and if you have to remove the valve covers you will have to drop the engine. That came from boss330 on corral.
I just got my 2vpi heads in and they came off a 5.4 , man i'm sorry dissapointed in them now. The heads "looked" great but when i took the cams out, i could tell that the motor had some major problems. The bearing surfaces looked like some small farmer plowed rows in them.....Took it to my engine builder and he said that he seen worse and to take some really fine sandpaper or some scotch bright and lightly work out the high spots, and then put a little oil on them and put some good cams back in and see if it turns easy without the arms in there. If so then the small ruts won't hurt a thing. Shooooooo. that was something decent to hear. So i'm praying that the things can be salvaged. Pray for them guys.
Old Apr 28, 2007 | 12:06 AM
  #1596
Blitzmann's Avatar
My tax return should arrive soon which means I will have plenty of cash to finish up my 5.4. Should have everything completed by late August/early September.
Old Apr 28, 2007 | 08:45 AM
  #1597
VOID's Avatar
sounds nice dude
Old Apr 28, 2007 | 09:53 AM
  #1598
Blitzmann's Avatar
Originally Posted by VOID
sounds nice dude
I've had my bareblock sitting on an engine stand for like 2 months now lol.
Old Apr 28, 2007 | 06:15 PM
  #1599
i'm just waiting for some free time...
Old Apr 28, 2007 | 06:56 PM
  #1600
VOID's Avatar
lol yea, i just waiting on some money to fall from the sky and into my lap. Seem like every time i get some something happens. I got a little saved up and i'm going to have to work on those heads and i moved my car today for the first time in like a week and notice i had a big puddle of oil under it. Man, its always something. Hope its just a pan gasket or something.
Old Apr 29, 2007 | 08:57 AM
  #1601
all good things come to those who wait. myillwill has his put together and it's still taking time to get the thing running and tuned. We'll all get there in time.
I've moved on to doing some AN fittings and lines. Getting rid of the rubber lines for my oil cooler. Should be cool looking. Gunna be fun.
Old Apr 29, 2007 | 09:56 AM
  #1602
VOID's Avatar
i've always caught heck with those AN fittings ..... bloody knuckles on the vise all the time
Old Apr 29, 2007 | 01:23 PM
  #1603
turned out I only had the right fittings to do half of it. So... there's half of my oil cooler connected via braided lines and AN fittings. Teflon core under the car and in exposed/abrasive-prone areas, rubber core through the body panels.
I've never had a really bad time assembling them but you kinda have to get all the tricks down for each fitting type and hose type. Lots of details. Looks so much better though.
Old Apr 30, 2007 | 01:50 PM
  #1604
VOID's Avatar
nice, i just got a pm from another site where a guy is selling a 99 5.4 2v from an expedition , it has 103k on the clock and it has "external head gasket weap" never heard of that, but the guy said it needs new head gaskets and he wants 400 plus shipping for it, shipping is gonna be around 260/300 to get it shipped what you guys think,
O and i found a set of 5.4 "lightning" h beams for 100 bucks plus shipping, he said they where new and he would throw in some rod and some other bearings sounds good, just wondering if they are really lightning forged rods.
One more thing. What would a 11cc piston make compression wise on these motors?
Old Apr 30, 2007 | 02:22 PM
  #1605
lightnings came with the same rods that come in all the other 5.4 2v's... crap. They break them too. They're I-beams if they're lightning rods. If they're just 6.658" H-beams then that may be a good thing. You'd have to know cuz we can't be good with speculation. If the bearings he throws in are new then groovy otherwise he's just adding weight to the pallet.
The motor seems like a good buy. If it comes with a front cover that pays pretty much for itself right there.
An 11cc dish would make right around 9.3:1 on a standard bore.
Old Apr 30, 2007 | 06:59 PM
  #1606
VOID's Avatar
Well i'm not sure what forging they are but they look ok and they come with new rod and main bearings . I uploaded this pic, I also run up against a bare block with a crank and timing cover for 50 bucks. But does my stuff transfer from my 4.6 cover swap over? I might just save up for that motor and then bore it over a little and throw some flat tops in it with good rings and put some n02 on it and call it a day.
Attached Thumbnails Anyone intrested in 5.4L swaps, in here. Need you to opine.-zzzzzzzzzzzzzzzz.jpg
Old Apr 30, 2007 | 10:29 PM
  #1607
VOID's Avatar
Ok so i just was wondering, the lightning....it had cast rods, cast crank and cast pistons or just the rods and crank? just wondering....I have done desided that i'm going to go the lightning style motor set up. I'm going to get the 5.4 long and then mod with lightning supercharger and stuff. Is there any difference between that and the regular 5.4 in terms of front cover or anything? thanks guys
Old May 1, 2007 | 07:54 AM
  #1608
Blitzmann's Avatar
That will probably be a really tall engine, would need an insane cowl hood for it to work properly.
Old May 1, 2007 | 08:27 AM
  #1609
Those are nice rods by the look of it. All con-rods are forged (except possibly billet but those don't count), it's just a matter of what material, and the overall design intent. There are some wicked strong rods of the I-beam type that comes stock, stock aren't among them. Pistons in a lightning are forged 2618 aluminum with a nice dish. The stock cranks vary from year to year but early on they were forged. Later on came the cast crank which is strong enough for any street application. Non-lightning 5.4's came with hypereutectic (lots of silicon) cast pistons with a slight dish. They're nice but not super strong.
you'll have to go the hole in the hood route to use a lightning blower. Why not save all that hassle and slap a novi 2000 or a Vortech T trim on it and have it fit under the hood? You probably wouldn't be street legal with a big enough cowl and the hood will cost you several hundred bucks plus paint which is about the difference in cost to getting a new blower kit for a 4.6 and slapping it on your 5.4 with a manifold approaching normal.
what bolts are in the rods? ARP 2000 or what?
Old May 1, 2007 | 09:27 AM
  #1610
VOID's Avatar
Not sure about the bolts. I need to ask him. There is a guy on corral that has the lightning in his car and the thing has a custom sheet metal intaka dapter so that it will fit under a tall cowl or cobra r. I think i got some pics so ill post them. I just really like the idea of just swapping the supercharged motor in.
If you were going to go with this rout, would you just buy the whole lightning motor with supercharger wiring, computer and trans and just swap everything or just go with the whole motor and swap in? Ill post some pics.
Attached Thumbnails Anyone intrested in 5.4L swaps, in here. Need you to opine.-dcp_1255.jpg   Anyone intrested in 5.4L swaps, in here. Need you to opine.-dcp_1201_edited.jpg   Anyone intrested in 5.4L swaps, in here. Need you to opine.-img_0341_medium_2_.jpg   Anyone intrested in 5.4L swaps, in here. Need you to opine.-img_0363_medium_.jpg   Anyone intrested in 5.4L swaps, in here. Need you to opine.-img_0367_medium_2_.jpg
Old May 2, 2007 | 09:30 AM
  #1611
that's a big nasty cowl but if you're down for it... have fun. I'd ask him about the whole wiring thing. I'm going the easy route. For me it's my harness and ECU and just a tune. With the L blower it'd be a little more involved in the tuning but I'm not sure about the harness.
Old May 2, 2007 | 09:59 AM
  #1612
2Eighty1's Avatar
Here is a question. Well a few
On a 5.4 SOHC Vorteched fully forged.
Number 1: is 6500 rpm to much, I know the cams will determine the power but will the motor hold it
Number 2: Do I need a windage tray ?
Number 3: Should I use stock or aftermarket Oil Pan
Bumber 4: If you said aftermarket to #3 - which one : http://www.lethalperformance.com/pag...-oil-pans.html
Old May 2, 2007 | 10:21 AM
  #1613
That's a pretty high engine speed. I think limiting it to 6000 or so will return better results given the high piston speeds associated with the uber long stroke.
For any performance engine a windage tray is not a bad idea.
Either the stock mustang pan which will have to be mildly modified (beaten with a hammer in places...nothing special) or an aftermarket. I like enhanced oil reserves available with milodon and canton 7qt pans. An oil cooler is also not a bad idea but not required either.
Look at other retailers... lethal seems to have a very limited product line. Check out MMR's website... www.modularmustangracing.com. They have a few too.
Old May 2, 2007 | 11:44 AM
  #1614
VOID's Avatar
so just for the swap i would need to beat in my oil pan??? wow that don't sound good. I do agree rEd that its a nasty looking hood but to each their own. I would go with s little lower R hood and cut a little to let the sheet metal show but i would paint it either white or tan or black to match the car. I don't know though. I might just buy a 5.4 2v and put some nitros or vortec on it. depends. I've seen a harley dav. motor with supercharger for 3500 complete on ebay, so i might just do that.
That guy with that car lives like an hour or two away. I am in the process of talking to him about seeing the car. He didn't do the swap, he bought it from a repo yard for like 2k. What a project car to get repoed........
There is to many choices.
Old May 2, 2007 | 03:38 PM
  #1615
Blitzmann's Avatar
What do you all think of this hood.
With the stock spoiler and mach one chin.
Old May 2, 2007 | 04:15 PM
  #1616
VOID's Avatar
I like that because the hump goes all the way to the end of the hood. Do you have a lightning motor under there?
Old May 2, 2007 | 04:37 PM
  #1617
that looks mean as hell....
Old May 2, 2007 | 08:17 PM
  #1618
Blitzmann's Avatar
Not my car, guy couple hours from me has it. I think its for show, as he is 4.6 N/A. I plan on getting that one though to clear everything and make room for turbo and all that jazz.
My thoughts exactly.
Old May 2, 2007 | 08:53 PM
  #1619
VOID's Avatar
that looks really nice, i think it looks better on the 99 up cars since its more agressive looking than the 94-98 ones.
Old May 4, 2007 | 10:36 PM
  #1620
VOID's Avatar
so guys any more word on your cars? how is things comeing? I think before i settle on the lightning motor idea i'm going to ride in that dudes car and see how it feels. I just can't imagine my sleek car with such a big hood.......I might just have to get the plates and then put a svo supercharger or a k/b on it. or maybe vortec/ or turbo.....God too may options. I think i'll just start with a n/a 9:1 motor and go from there. Man i wish i could make up my mind and stick to it.
What you guys think of the SVO Blower with the plates. Should fit under my hood with no problems and give me loads of torque and with some good blower style cams and 12 pounds if possible then it should be a pretty nice thing huh?
