Idle problem back.....AGAIN!!!!!!
Old Apr 16, 2007 | 07:15 PM
ericgutz's Avatar
Default Idle problem back.....AGAIN!!!!!!
This idle thing is really getting annoying. All started a couple of months back after i replaced the air filter on my CAI with a new K&N filter. After that, the car would idle really low (about 100-200 rpm), then stall out and turn off. I messed with the air filter and the problem went away.
Problem came back about a month ago, I cleaned out the MAF and throttle body and the problem went away.
Problem came back yesterday, so i just took out the damn CAI and put the damn stock air intake back in and cleaned out the MAF again. Only this time, the problem is still there.
The car works when i give it some gas to keep the idle about 500rpm. When driving, it works and seems to run fine while in gear, but every time i switch gears, the rpms drop way down while in neutral. And when i'm slowing down to a stop, the rpms drop and the car stalls out sometimes.
Any ideas?
Old Apr 17, 2007 | 05:31 AM
Sounds like you have a monster vaccum leak or a sensor is unpluged or was damaged. Do you have any codes or is the check engine light on?
Old Apr 17, 2007 | 08:15 AM
4.6 Love's Avatar
Sounds like you have an IAC problem to me.....clean it with some carb cleaner and I bet that fixes your problem...
Old Apr 17, 2007 | 11:58 AM
ericgutz's Avatar
Where is the IAC? I know it's around the throttle body, but there's two things there and i'm not sure which is the IAC.
Old Apr 17, 2007 | 12:03 PM
here, now thats not on a Mustang but similar and if you need to buy one, DO NOT buy aftermarket. get an OEM Ford one, oh and change your PCV Valve too as thats the leading cause of IAC failures, not changing a PCV and again, Buy OEM
File Type: jpg
Old Apr 17, 2007 | 12:12 PM
ericgutz's Avatar
Thanks, i'm gonna pull it off and clean it out. If i do need a new IAC and/or PCV valve, what kind of $ am i looking at.
And my check engine light did turn on today on the way home. Does autozone or any other place have something to read the code?
Old Apr 17, 2007 | 12:34 PM
what year?
Old Apr 17, 2007 | 12:36 PM
ericgutz's Avatar
2000 Gt
Old Apr 17, 2007 | 12:53 PM
$75.00 for the IAC wth gskt and $6.50 for a PCV valve thru us, + shipping and in stock
Old Apr 17, 2007 | 12:56 PM
ericgutz's Avatar
I'm getting ready to head over to the local ford and get a new PCV, might as well replace it while i clean out the IAC.
How would i know if the IAC is bad? If it is, i'll order it through you cuz the local dealership wants $110.19 for it.
Old Apr 17, 2007 | 01:21 PM
ericgutz's Avatar
Okay, i've got the IAC off. Does it matter which direction i spray it from? And what should i use, i've got some MAF cleaner and some throttle body/air intake cleaner?
Old Apr 17, 2007 | 01:42 PM
i have used carb cleaner and brake cleaner with good results because there prettu tuff and getting carbon out of there. I dont think the Tb and intake cleaner is good enough for that. The maf cleaner is to weak and wont work. Try the TB cleaner and see if it works. spray the crap out of it.
Old Apr 17, 2007 | 04:05 PM
ericgutz's Avatar
Smile
Fixed. Put in a new PCV and cleaned out the IAC with some carb cleaner. Works like a charm now.
I'll probably go ahead and put my CAI back on this weekend.
Thanks for all of your help. You guys definitely know your ****.
Old Apr 18, 2007 | 02:17 PM
4.6 Love's Avatar
I told you that was it bro...
Icefreezen
Apr 13, 2010 02:46 AM
machnjo
Jun 27, 2007 07:52 PM
ericgutz
Mar 12, 2007 11:54 AM
Shambles
32
Dec 20, 2005 10:51 PM
drewbhot
May 25, 2005 08:39 AM
