abs when changing rotors?
Old Apr 1, 2007 | 09:25 AM
Redfire-01's Avatar
Default abs when changing rotors?
I'm changing rotors for first time and they are stuck like a sucka!! Is there something I'm missing..I've removed caliper and now trying to bang the old rotor off! Are there any special tricks to this?
Old Apr 1, 2007 | 09:29 AM
Redfire-01's Avatar
Oh by the way it's an '01 GT front rotors.
Old Apr 1, 2007 | 09:47 AM
Redfire-01's Avatar
me again..The reason for the ABS in the question is that I read somewhere online that the ABS may have to be disabled in order to remove the rotors. Is there any truth to this or are rotors just that hard to remove! There is a small torx bolt on the spindle with a hose line leading upwards is this for the ABS? this bolt is on the spindle not the caliper itself..and it leads in towards the wheel well? please help I'm a first timer!
Old Apr 1, 2007 | 07:30 PM
You don't need to remove the ABS to remove the rotor. Did you remove the push-nuts on the studs? Ford puts 2-3 of these washer looking things on the wheel studs to keep the rotor in place. If that doesn't work, just wack to back of the rotor until it loosens.
Old Apr 3, 2007 | 09:30 PM
Redfire-01's Avatar
my rotors did not have the push nuts or clips on the studs. I just had to be persistent and aggressive with a big hammer to break the rust adhesion from the old rotors. Success at last!!!!!!!!!!!!!!!!
Old Apr 10, 2007 | 06:43 PM
They get stuck on there good.
n1ftyneil
Nov 8, 2012 02:36 PM
batplus4
Apr 19, 2010 12:34 PM
89stang
Jan 6, 2006 02:03 PM
WhitePony
Dec 21, 2005 08:54 PM
donnyonee
Sep 7, 2005 09:35 AM
