Where to find a nice Catch Can?
Old Mar 28, 2007 | 07:49 AM
Default Where to find a nice Catch Can?
Im looking for a nice oil catch can. I would like something that is racy looking. Maybe like something stainless steel that already comes with AN fittings. Where can I find some? Trying to get this done before my retune. I figured I could put this on then run a bunch of seafoam through to clean out the oil and maybe itll make like 5more hp when its retuned.
Old Mar 28, 2007 | 08:32 AM
maybe, try www.bsrproducts.com
Old Mar 30, 2007 | 09:12 AM
El Diablo's Avatar
Old Mar 30, 2007 | 10:23 AM
I found a nice Greddy catch can im going to try. Thanks!
Old Mar 30, 2007 | 10:55 AM
I make them.... peep delta:
Old Mar 30, 2007 | 03:35 PM
Well I see you use the large air/water seperators. The one I have on it now is the small type. Its just for temporary because my engine is drinking oil! Its coming from the PCV valve AND I just found that its leaking oil from the impeller! Ahhh!
Old Mar 30, 2007 | 05:31 PM
I skimp on nothing. If you want a kit, let me know. Blower cars don't do well with crappy kits. If you want a 2 stage filter I can set that up too.
Old Mar 30, 2007 | 07:10 PM
I may get you to build me one. Im not really too sure if the oil is coming from the impeller or not. It has zero shaft play and theres no oil actually on the impeller. Well its got a thin coat just like my discharge tube does. Barely any oil getting into the discharge but it seems the oil may be mixed with the air. I looked at the 2 hoses going to my powerpipe and theyre bone dry. The BPV is dry also. I dont know where its coming from. Its dripping down onto my filter I believe. I took the elbow off and watched the impeller spin while it was running. I gave it steady throttle and saw no oil spitting from the impeller.
Old Apr 1, 2007 | 11:48 AM
You need the filter anyway... blower cars should all run at least a single stage if not a 2 or 3 stage (depending on boost). Send me some under-hood pics to cburnss at gmail dawt com. Make sure you get pics with detail of your PCV system from end to end and a couple close ups of the front of the upper plenum/TB area.
I may be able to fix your issue with just a properly designed check valve setup. And yeah... all my shizzle is AN fittings and braided stainless hose. Top shelf. Ask blake.
Old May 31, 2007 | 01:16 PM
OXFORD03GT's Avatar
LET THE MODDING BEGIN...
Arrow Oil seperator.
Pm sent.
(R3dN3ck)
Brian.
Old May 31, 2007 | 01:35 PM
replied...
here's some pics of another board member's new sep that I just finished and shipped:
state-of-the-bad-ass-art"
29
Oct 7, 2022 05:01 PM
May 2, 2010 05:34 PM
venom
May 25, 2009 12:06 PM
Jack The Ripper
Sep 8, 2005 11:43 AM
Shawns2002GT
New Members!
Jun 28, 2005 05:12 AM
