Couple of questions. Please help.
Old Mar 23, 2007 | 05:32 AM
well first off Im not a big fan of seafoam, your hesitation could be from worn-out O2's or othe emmission related parts or something a good tune-up would cure, seafoam is just a "band-aid" approach to fixing the real problem.
now the tranny problem could be low on fluid, so I'd change it as it's pretty easy to-do or it could be a sign that the clutch is going south and worse case, the trans is in need of a re-build
Old Mar 23, 2007 | 06:04 AM
mcmmotorsports's Avatar
Resident Mental Patient
I have been running Lucas Semi-Synthetic ATF in my TR-3650 since about 2,000 miles and NO problems whatsoever.
Old Mar 23, 2007 | 07:50 AM
when you did the tune-up, did you buy Ford O2's or aftermarket? also mileage has nothing to-do wth it as a car can de-grade quickly from sitting then from being driven all the time
seafoam, well Im just not a fan of "snake oils" or things of that nature.
as far as the trans fluid, no sense in spending alot on synthetics at this point so I'd go wth @3 qts of regular old Mercon III att
Old Mar 23, 2007 | 08:21 AM
NO, DO NOT USE anything heavy like 75weight oil in a manual trans, Ford uses regular old ATF/Mercon III
Now on the O2's, Ford's are very sensitive when it comes to electrical componets like sensors and anything aftermarket like IAC, IAT, O2's TPS and other electronic sensors DO NOT work well in Fords and just because you dont get a check engine lite doesn't meen the sensors are reading correctly
Old Mar 24, 2007 | 03:12 PM
Originally Posted by wnracing
Just wanted to say Thanks for all of your help Randy, you are an invaluable assett to the site and you helped me alot!
YOUR WELCOME!!
J/K
zegimp
Aug 29, 2008 04:47 AM
holmes14
Mar 31, 2007 06:03 AM
97stanger
21
Aug 3, 2005 01:02 PM
BeatTheBrat94
Jul 13, 2005 12:40 PM
Joyrider564
Jul 13, 2005 08:13 AM
