Old Mar 12, 2007 | 05:12 PM
  #1291
VOID's Avatar
Totaly pimpalicious 5.42v
yea i would think it might not fit though.
Old Mar 12, 2007 | 05:59 PM
  #1292
stang671's Avatar
so does that mean you would have to buy the SC for a 5.4L.....thanks for taking the time to read this...
Old Mar 12, 2007 | 07:08 PM
  #1293
VOID's Avatar
naw its just the aftercooler kit for vortec "i think" fits on the side of the valve cover but it might not fit between the valve cover and the side of the engine bay. thats all.
Old Mar 12, 2007 | 07:22 PM
  #1294
stang671's Avatar
so where would you have to place it then...is there any way to modify it so that it can fit else where or does it have to sit on the side...thanks for taking the time to read this...
Old Mar 12, 2007 | 07:24 PM
  #1295
2V4NOW's Avatar
Originally Posted by VOID
wow sounds like he should swap the stock cams back in. lol thats why i want this motor so bad. It looks so stock. Anyway, you could do that thing with the removable cats and just put them on for the sniffer test and then take them off, or run really high oct and it burns way more efficiently right? i don't know that much since i'm on east coast in NC and the inspector just ask if the signals work and how about the horn lol.
You like the stock look, how bout this dudes stang?
Old Mar 12, 2007 | 07:26 PM
  #1296
stang671's Avatar
Void is that your stock drive train...or did you upgrade...thanks for taking the time to read this....
Old Mar 12, 2007 | 07:32 PM
  #1297
stang671's Avatar
why would one do that...that shows off what you have (sort of)...i don't know i dont' think it looks all that cool....but that's just one opinion...thanks for taking the time to read this....
Old Mar 12, 2007 | 09:46 PM
  #1298
VOID's Avatar
thats what i originaly wanted to do. that is soooooo baddddd assssssss. I rode in a car with the swap like that and it had a some "how would you say....traction problems" but it was hellishly fast , fast , fast, fast , fast .....
Old Mar 12, 2007 | 09:48 PM
  #1299
VOID's Avatar
What do you mean stock drive train? as of the moment the car has the stock npi 4.6 with just a little mods done to it. Its a cmpletly stock auto and rear. so basicaly stock.
Old Mar 13, 2007 | 08:05 AM
  #1300
stang671's Avatar
I'm sorry i thought you already had that engine in the car...i appoligize...thanks for taking the time to read this....
Old Mar 13, 2007 | 08:59 AM
  #1301
VOID's Avatar
No problem man, it won't take to long for me to gather everthing up ,money willing, and slap it in my car. But after i do that i'm deffinitly getting a tune and a converter. Tell me guys, what gear do i need to run with this car with my 4r70w? a 3.73, 3.90, or 4.10?
Old Mar 13, 2007 | 10:18 AM
  #1302
I'm using 3.55's in mine. Any more than that and traction becomes too much of an issue for my tire budget to handle. I figure, 280tq now, probably 350 or better post install... definitely not gunna be able to afford 3.73. Saleen S330 had 3.73's and zero traction outside of 4th gear with 366tq.
In any case I think the smart money will be on a good size air:air intercooler. You've got enough heat and metal under the hood as it is with an oversized motor and a big old blower, may as well not add to the density issue. ATI makes really nice coolers. You'll need a kit of boost pipe bends and lengths to get it installed and the battery will probably need to be relocated.
I just picked up a set of superior axles (finish off the upgrades to the back end), white face guages(cheap... why not) and billet fuel rails. I need to find a set of 32lb injectors on the cheap and then I'll have the intake setup completed. The days are zooming by and I'm not making the progress I'd hoped but soon... sooon. Famous last words.
Old Mar 13, 2007 | 12:11 PM
  #1303
01GTBlown's Avatar
"kill or be killed"
Has anyone looked into using the T-56 6 speed viper transmission with the 5.4? Will it even bolt up?
Old Mar 13, 2007 | 12:13 PM
  #1304
bolts right up.. need a few other parts for the conversion though. It's not hard.
Old Mar 13, 2007 | 01:00 PM
  #1305
Just needs to have a bellhousing adaptor (or bellhousing, can't remember if the T56 is integrated or not), the correct clutch disc, rear yoke, and shorter driveshaft.
Old Mar 13, 2007 | 01:29 PM
  #1306
VOID's Avatar
I know my car has the stock 3.27 or 3.23 something, should i stick with it? or what? so with my auto traction wouldn't happen with 3.73? on the street i woujld use regular street tires but at the track i would use M/T ET Streets.
Old Mar 13, 2007 | 02:11 PM
  #1307
You are talking about 400+ ft-lbs coming out of the engine at rpms below 3,500-4,000 rpm w/ a torque curve that's almost flat. Combine that w/ a big rear gear and street tires and you will not hook up. You should stick w/ nothing more than a 3.90:1 rear gear. The torque alone will make up for the lack of gearing.
Old Mar 13, 2007 | 02:13 PM
  #1308
if you're going to use ET's then get as beefy a rear end as you can. I'd go up to 31 spline and aftermarket diff... regardless of the gear with that tire. You should also have a driveshaft safety loop installed. 3.27 is fine if a little long. I like 3.55's better on my 4.6 and with the 5.4 they should be more than sufficient. 3.73's on an auto would be a fuggin h00t. Beef up your tranny or you'll frag something. 3650's are teetering on the edge with a 5.4... 4r70w needs some help if you're going to race it.
Old Mar 13, 2007 | 02:17 PM
  #1309
ohh.... thought you meant a viper spec (like the gearing). a pullout from a viper, I seem to recall that's a bellhousing and tailshaft housing away from working. Of course there are crossmember issues and you have to deal with the clutch. Viper clutches are hydraulic. I don't know how much of a conversion issue it is outside the bellhousing and clutch fork.
Old Mar 13, 2007 | 06:44 PM
  #1310
VOID's Avatar
yea i think ill stick with the 3.73's but i heard that the 4r70w can take 350 hp and 450 lb. so, i was going to do that and a shift kit and converter. should be nice. :O
Old Mar 13, 2007 | 06:49 PM
  #1311
hey r3dn3ck, i might have some 39#'s off an 03 cobra for sale soon
Old Mar 14, 2007 | 09:29 AM
  #1312
I don't know if they'll plug into my harness... If they will (even with a little tinkering) let's work a deal.
VOID... The rating is more for where you can expect breakage. Accelerated wear and subsequent breakage is another story. I recall reading in another thread on here about some people getting broken input shafts on the autos. I'd leave the converter alone or just get a stronger built one with the same stall RPM... your peak torque will start coming on right about where the stocker stalls so it's not a bad one from that stand point. I generally refuse to deal with autos so I'd recommend you tap one of the guys here that knows their auto-stuff.
Old Mar 14, 2007 | 10:41 AM
  #1313
mmr sells harness adapters for the new style plugs.
everyone post pics of thier project so far...
Old Mar 14, 2007 | 11:19 AM
  #1314
chip6990's Avatar
Mustang Junkie!!!!!!!
well guys, remember back a few months back i had decided to sell all my 5.4 2V stuff. well i didnt sell anything, so i guess i am back in the game. i might take the block to the machine shop this week. i am still undecided as to get a set of aftermarket heads or just put my hand ported PI heads that are shaved .03 (which currently house Comps XE268's), or hand port my factory PI heads and install the Comp 270's i have. everything will be forged, to yield about 9.1CR, and about 12-14#'s of boost. i found a shop that could fab my Mac L/T headers to the 5.4.
Old Mar 14, 2007 | 11:43 AM
  #1315
sounds good to me chip...
Old Mar 14, 2007 | 02:24 PM
  #1316
VOID's Avatar
nice.
Old Mar 14, 2007 | 02:44 PM
  #1317
chip6990's Avatar
myillwill...where are you located?
Old Mar 14, 2007 | 03:25 PM
  #1318
birmingham ala
Old Mar 14, 2007 | 03:36 PM
  #1319
chip6990's Avatar
you aint that far away, i live in Greeneville TN
Old Mar 14, 2007 | 04:11 PM
  #1320
Got a link? I didn't see them on their site. <prepares to call MMR>
In any case... those seem like a decent option. LMK what you're looking to get out of them and what kind of use they've seen.
